holley carb flooding problem #368281
07/06/09 03:24 PM
07/06/09 03:24 PM
levittown,pa.
K
knuckelbuster Offline OP
K
levittown,pa.
Holley 600 with vac. secondaries.rebuilt with a holley kit but it has gass leaking past the throttle blades on all four barrels where the idle bleed are.took apart 3 times and cant figure out what the deal is.floats are set correctly.help! this is drivin me nuts.
Dan
Re: holley carb flooding problem [Re: knuckelbuster] #368282
07/06/09 04:33 PM
07/06/09 04:33 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Are the floats full or have any fuel inside. They are known to fill and sink on occasion.
Could be dirt in the needle and seat.
Re: holley carb flooding problem [Re: RobX4406] #368283
07/06/09 04:55 PM
07/06/09 04:55 PM
levittown,pa.
K
K
levittown,pa.
floatss ok needle and seat ok
Re: holley carb flooding problem [Re: knuckelbuster] #368284
07/06/09 05:39 PM
07/06/09 05:39 PM
Az
Crizila Offline
Crizila  Offline
Az
What kind of fuel pressure ae you running?
Fastest 300
Re: holley carb flooding problem [Re: Crizila] #368285
07/06/09 06:15 PM
07/06/09 06:15 PM
levittown,pa.
K
K
levittown,pa.
Dont know.its a new pump but i had the problem before i replaced it. its mechanical.Dan
Re: holley carb flooding problem [Re: knuckelbuster] #368286
07/06/09 06:56 PM
07/06/09 06:56 PM
grant louisiana
mayhem148 Offline
mayhem148  Offline
grant louisiana
check all the vents and air bleeds. sounds like you have something plugged up. where did you get your rebuild kit?
Re: holley carb flooding problem [Re: mayhem148] #368287
07/06/09 08:43 PM
07/06/09 08:43 PM
levittown,pa.
K
K
levittown,pa.
holley kit from speed shop
DAN
Re: holley carb flooding problem [Re: knuckelbuster] #368288
07/06/09 09:42 PM
07/06/09 09:42 PM
Az
Crizila Offline
Crizila  Offline
Az
Assume you are running a fuel filter?? Remove the fuel line at the carb and plug it. Start the engine and run the carb dry. Re connect the fuel line and fire it up. This proceedure will often work to flush ant dirt past the needle and seat - if that's the problem. Assume you replaced the needle & seat with a Holley matched set? Check the floats for leaks and the float hangers for any binding. Did you set the float levels manually? Don't know how you could have done it with the sight plugs if it was flooding.
Fastest 300
