Re: 440 into cuda
[Re: 420duster]
#367686
07/05/09 11:19 PM
07/05/09 11:19 PM
RapidRobert
Kmember is the same(just need BB mtr mts) trans X member the same(but need BB 727). 68-70 BB iron ex manifolds($250-400) or TTI headers(you dont want to know how much right now)
Re: 440 into cuda
[Re: RapidRobert]
#367687
07/05/09 11:31 PM
07/05/09 11:31 PM
Posts: 565 IA
landon1
IA
in my 71 satellite, whoever did the swap used the saginaw ps pump and even the hoses. it had headers when i got it and has headers now, but for awhile, i ran late non-HP manifolds. they were even able to use the stock HD radiator by using a late passenger outlet wp housing (no a/c on 440)
'71 Satellite Sebring 440
Re: 440 into cuda
[Re: 420duster]
#367689
07/13/09 01:44 PM
07/13/09 01:44 PM
Ok,the motor and tranny came out of a 72 newport, is the tranny going to match up ???
Yes! Get as much as you can from the car. The motor mounts will work, the radiator will work (grind a little off of one side to clear the frame), shorten the driveshaft, etc.
That's the best way to do a swap into an E or B body. Find a good C donor and your 99% there!
