Re: Identify This Power Steering Pump Reservoir
[Re: ohiodemon]
#367080
07/05/09 12:21 PM
07/05/09 12:21 PM
Posts: 4,687 VA
69 Road Runner
VA
I know it's a Saginaw, but it doesn't match the ones at the parts store.
The connections aren't in the same place.
69 Road Runner Vert
[Re: 69 Road Runner]
#367082
07/05/09 01:59 PM
07/05/09 01:59 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
We pulled this reservoir off a 400, but it wasn't original to that engine. It leaks, and I can't find a replacement in the Napa catalogs.
Any idea what the original application is? I've put a Hemi in a non-Hemi car, and this bracket that I got from Bouchillon (I think) won't allow for an original pump.
That's the same pump that was on my 78 Trailduster.Used in a lot of different applications in mid to late 70's
[Re: biginchmotor]
#367084
07/05/09 03:05 PM
07/05/09 03:05 PM
Posts: 4,687 VA
69 Road Runner
VA
Sorry I couldn't get a better picture, but it's hard to get the camera at the right angle.
The high pressure line connects to a male fitting in the middle at that very bottom of the back of pump.
The low pressure line connects just a little higher, but on the driver's side of the back of the pump.
69 Road Runner Vert
#367085
07/05/09 03:19 PM
07/05/09 03:19 PM
Posts: 4,687 VA
69 Road Runner
VA
I just looked at the 1 for a 76 Cordoba with a 360, and that does look like it might be close enough.
I just took another look, and the low pressure line comes off the bottom of the pump. The Rock Auto picture has it come off a little higher, but looks like it would clear the bracket.
69 Road Runner Vert
#367086
07/05/09 03:41 PM
07/05/09 03:41 PM
Posts: 27,480 So Cal
autoxcuda
So Cal
The pressure line you have now sure looks like the one on my 383 Challenger with saginaw pump. I also use that same line on my 68 340 saginaw pump.
ACDelco Part # 36-352830
http://198.208.187.182/internet/PartImage.jsp?mfgname=&prodlinecd=&acpartnbr=36-352830
GATES Part # 352830:
This picture is sort of upside down the way it is actually installed on the car.
[Re: autoxcuda]
#367087
07/05/09 07:29 PM
07/05/09 07:29 PM
Posts: 4,687 VA
69 Road Runner
VA
It could be the same hose. The bracket is my problem.
Some reservoirs have the fitting in the middle, and that won't work with this bracket.
I need both the low and high pressure to be at the bottom.
69 Road Runner Vert
