Identify This Power Steering Pump Reservoir #367078
07/05/09 08:30 AM
07/05/09 08:30 AM
VA
69 Road Runner Offline OP
VA
We pulled this reservoir off a 400, but it wasn't original to that engine. It leaks, and I can't find a replacement in the Napa catalogs.
Any idea what the original application is? I've put a Hemi in a non-Hemi car, and this bracket that I got from Bouchillon (I think) won't allow for an original pump.
69 Road Runner Vert
Re: Identify This Power Steering Pump Reservoir [Re: 69 Road Runner] #367079
07/05/09 08:41 AM
07/05/09 08:41 AM
wilmington,ohio
O
ohiodemon Offline
ohiodemon  Offline
O
wilmington,ohio
that is a Saginaw power steering pump.
Re: Identify This Power Steering Pump Reservoir [Re: ohiodemon] #367080
07/05/09 12:21 PM
07/05/09 12:21 PM
VA
VA
I know it's a Saginaw, but it doesn't match the ones at the parts store.
The connections aren't in the same place.
69 Road Runner Vert
Re: Identify This Power Steering Pump Reservoir [Re: 69 Road Runner] #367081
07/05/09 01:08 PM
07/05/09 01:08 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Does the pump have a female compression fitting in the rear?
I would look at the 71 Challenger 383 A/C saginaw pressure hose on rock auto for picture. That pressure hose has a male compression fitting at the pump and a female compression fitting at the box.
Re: Identify This Power Steering Pump Reservoir [Re: 69 Road Runner] #367082
07/05/09 01:59 PM
07/05/09 01:59 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
That's the same pump that was on my 78 Trailduster.Used in a lot of different applications in mid to late 70's
Re: Identify This Power Steering Pump Reservoir [Re: 62maxwgn] #367083
07/05/09 02:02 PM
07/05/09 02:02 PM
Connecticut
biginchmotor Offline
Connecticut
That pump also looks identical to the pump on my 1976 Cordoba, 360 engine...John.
Re: Identify This Power Steering Pump Reservoir [Re: biginchmotor] #367084
07/05/09 03:05 PM
07/05/09 03:05 PM
VA
VA
Sorry I couldn't get a better picture, but it's hard to get the camera at the right angle.
The high pressure line connects to a male fitting in the middle at that very bottom of the back of pump.
The low pressure line connects just a little higher, but on the driver's side of the back of the pump.
69 Road Runner Vert
Re: Identify This Power Steering Pump Reservoir [Re: 69 Road Runner] #367085
07/05/09 03:19 PM
07/05/09 03:19 PM
VA
VA
I just looked at the 1 for a 76 Cordoba with a 360, and that does look like it might be close enough.
I just took another look, and the low pressure line comes off the bottom of the pump. The Rock Auto picture has it come off a little higher, but looks like it would clear the bracket.
69 Road Runner Vert
Re: Identify This Power Steering Pump Reservoir [Re: 69 Road Runner] #367086
07/05/09 03:41 PM
07/05/09 03:41 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
The pressure line you have now sure looks like the one on my 383 Challenger with saginaw pump. I also use that same line on my 68 340 saginaw pump.
ACDelco Part # 36-352830
http://198.208.187.182/internet/PartImage.jsp?mfgname=&prodlinecd=&acpartnbr=36-352830
GATES Part # 352830:
This picture is sort of upside down the way it is actually installed on the car.
Re: Identify This Power Steering Pump Reservoir [Re: autoxcuda] #367087
07/05/09 07:29 PM
07/05/09 07:29 PM
VA
VA
It could be the same hose. The bracket is my problem.
Some reservoirs have the fitting in the middle, and that won't work with this bracket.
I need both the low and high pressure to be at the bottom.
69 Road Runner Vert
Re: Identify This Power Steering Pump Reservoir [Re: biginchmotor] #367088
07/05/09 08:14 PM
07/05/09 08:14 PM
Az
Crizila Offline
Crizila  Offline
Az
and my 79 300 ( cordoba ) - 360
Fastest 300
