Steering column ground wire melted! #366844
07/04/09 09:05 PM
07/04/09 09:05 PM
Anonymous OP
Anonymous OP
The ground wire on the steering column of my GTX melted twice. The first time the horn circuit on the turn signal switch also melted and I thought
that was the cause of my problems. I replaced the turn signal switch and the ground wire and was able
to drive the car for a couple of days before the ground wire melted again, lucky for me no other damage. any ideas??
Re: Steering column ground wire melted! #366845
07/04/09 09:12 PM
07/04/09 09:12 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
What year?
Most likely you have a bare wire somewhere in the column. I'd tear down and inspect it.
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: Steering column ground wire melted! [Re: HealthServices] #366846
07/04/09 09:14 PM
07/04/09 09:14 PM
Anonymous OP
Anonymous OP
69, all the wiring was replaced with the new turn signal switch.
Re: Steering column ground wire melted! #366847
07/04/09 09:24 PM
07/04/09 09:24 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Only 2 things I can think of that will melt a ground lead,
excessive current load or to small a lead to begin with
ck all the dash frame ground path connections +/or install a larger grade lead for the grnd
Re: Steering column ground wire melted! [Re: gtx6970] #366848
07/05/09 04:10 AM
07/05/09 04:10 AM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Is it the ground wire that goes from the steering column to the dash frame or the black wire in the turn signal harness?
