Steering column ground wire melted!
#366844
07/04/09 09:05 PM
07/04/09 09:05 PM
The ground wire on the steering column of my GTX melted twice. The first time the horn circuit on the turn signal switch also melted and I thought that was the cause of my problems. I replaced the turn signal switch and the ground wire and was able to drive the car for a couple of days before the ground wire melted again, lucky for me no other damage. any ideas??
Re: Steering column ground wire melted!
#366845
07/04/09 09:12 PM
07/04/09 09:12 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
What year?
Most likely you have a bare wire somewhere in the column. I'd tear down and inspect it.
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: HealthServices]
#366846
07/04/09 09:14 PM
07/04/09 09:14 PM
69, all the wiring was replaced with the new turn signal switch.
