Page 3 of 3 1 2 3
Re: test fit car,trailer today. [Re: WILD BILL] #366509
07/05/09 06:40 PM
07/05/09 06:40 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
Why not just drive it in and climb out the window? That's what I do.
I leave the window down drive in open door a little and climb out no problem.The only reason I have a small winch is if its broke and wont run or drive.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: test fit car,trailer today. [Re: blownzoom440] #366510
07/05/09 06:43 PM
07/05/09 06:43 PM
Orlando Florida
blown572dart Offline
Orlando Florida
ok i will have to be more blunt.i am not getting a electric winch.
Re: test fit car,trailer today. [Re: blownzoom440] #366511
07/05/09 07:08 PM
07/05/09 07:08 PM
Cleveland Ohio
10secGTX Offline
10secGTX  Offline
Cleveland Ohio
what are you towing with?
Re: test fit car,trailer today. [Re: 10secGTX] #366512
07/05/09 07:14 PM
07/05/09 07:14 PM
ELYRIA,OH
blownzoom440 Offline OP
ELYRIA,OH
you had to ask.
my dakota extended cab 4.7L i am gunna give it a try.car&trailer 8,000lbs.
Re: test fit car,trailer today. [Re: blownzoom440] #366513
07/05/09 07:53 PM
07/05/09 07:53 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
you had to ask.
WRONG!! I can say one thing, Your Honest. You can tow it but I wouldnt go fast or far. But , You already know that Im sure.
Whats the truck itself rated for by its owners manuel. mike
Re: test fit car,trailer today. [Re: RussW] #366514
07/05/09 07:57 PM
07/05/09 07:57 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Man I must be doing something wrong, I drive mine all the way in and get out the door , I'm only 6'2" 350+. 04 Pace Shadow 28 ft. I do remove the swing out bar first though.
Thats what I do and I have a elec-winch ???
Re: test fit car,trailer today. [Re: Sport440] #366515
07/05/09 07:57 PM
07/05/09 07:57 PM
Orlando Florida
Orlando Florida
you had to ask.
Re: test fit car,trailer today. [Re: Sport440] #366516
07/05/09 08:00 PM
07/05/09 08:00 PM
ELYRIA,OH
ELYRIA,OH
you had to ask.
i would have to look but it is around 7,000lbs+.you are right i wont go fast or far and the ffreeway is flat.good electric brakes.
edit;With 3.55 Axle Ratio You Can Tow 5800 lbs
Gross Vehicle Weight Rating(GVWR)=6010
Payload=1448
Curb Weight=4562
Curb WeightFront / Rear=2728/1834
GAWRFront / Rear=3600/3600
Gross Combination Weight Rating(GCWR)=10500
With 3.92 Axle Ratio You Can Tow 7000 lbs
Payload=1448
Curb Weight=4562
Gross Combination Weight Rating(GCWR)=11700
Re: test fit car,trailer today. [Re: blownzoom440] #366517
07/05/09 08:51 PM
07/05/09 08:51 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Oh no Mike, Plan on burning up some transmissions and not much stability. Just being honest. With my 24' Haulmark and 3000# DartSport my 4.7 litre 'Ram' labored horribly all the way to and from the track and burned up the tranny. Switched to a Hemi Ram and all was good but too expensive for me.
Re: test fit car,trailer today. [Re: ProSport] #366518
07/05/09 08:57 PM
07/05/09 08:57 PM
ELYRIA,OH
ELYRIA,OH
thanks Bob.i will have to see about a new truck next yr.how much is a trans? i will have to ask the guy who does my 727 what he would charge.i gave the trans a test pulling about 2,000lbs of ferniture from florida& through verginia mountains.
Re: test fit car,trailer today. [Re: BILLYJAY] #366519
07/06/09 12:08 AM
07/06/09 12:08 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Dont get in the car...line it up and then winch it in the trailer (CENTERED) so you dont have damage issue...kepp the driverside window down in case you need to adjust the wheels or if you have lexan and cant roll them down, then kick the tire or put a guide down on the floor so the tire will follow without a driver in it... Good luck..
Me likes your 64!!
Re: test fit car,trailer today. [Re: dart4forte] #366520
07/06/09 02:32 AM
07/06/09 02:32 AM
Arizona
Chris'sBarracuda Offline
Arizona
Mike..
Drive it in and have someone help you center it.
Then use a tennis ball on a string and hang it from the ceiling so that it touches the windshield where you have a mark.
Leave the tennis ball permanently so you will always put it the same place..
Good Luck.
Chris..
Re: test fit car,trailer today. [Re: Chris'sBarracuda] #366521
07/06/09 05:05 AM
07/06/09 05:05 AM
ELYRIA,OH
ELYRIA,OH
Thanks Chris!i still have to start the car for the 1st time this yr.i can get on that now that things are setteling down for me.as life goes though other things seem to happing jast as you relax.
thanks all for your input.
Page 3 of 3 1 2 3
