Page 2 of 3 1 2 3
Re: test fit car,trailer today. [Re: blownzoom440] #366489
07/05/09 10:03 AM
07/05/09 10:03 AM
St. Louis Mo.
10 o to go Offline
"Happy Don"
10 o to go  Offline
"Happy Don"
St. Louis Mo.
Dont get in the car...line it up and then winch it in the trailer (CENTERED) so you dont have damage issue...kepp the driverside window down in case you need to adjust the wheels or if you have lexan and cant roll them down, then kick the tire or put a guide down on the floor so the tire will follow without a driver in it... Good luck..
that is what i did today.i have all stock windows,cranks.i was thinking of a guide but unsure of how. i dont want dammage from bouncing so thanks for the input on that!
did you get the car in thier with that winch and chain strap setup ? looks like you would have to reset several times and remove those chains and straps because it wont get up inside trailer enough .I have a 24 ft your winch is just at the fender i assume you cant get in to set park and would block wheels several times to set those chains are going to scratch the new floor.
We all gave our opinions since you posted it that what these sites do .
PROBLEM SOLVERS
2009 418" build dan smith built new 9.96 131.82 6.23 108 1.30 60 foot best to date 9/15/09 8in 727 430 dana 2860 lb 3040 lb w driver
Re: test fit car,trailer today. [Re: blownzoom440] #366490
07/05/09 10:09 AM
07/05/09 10:09 AM
Diego-Town, CA
Diego_Ted Offline
Diego_Ted  Offline
Diego-Town, CA
ok i will have to be more blunt.i am not getting a electric winch.
You are a crazy man!! Have fun LOL
Diego
Re: test fit car,trailer today. [Re: 10 o to go] #366491
07/05/09 10:11 AM
07/05/09 10:11 AM
ELYRIA,OH
blownzoom440 Offline OP
ELYRIA,OH
PROBLEM SOLVERS
OH YA i had to reset the cable,wheel chuck several times but will get a longer cable.just keeping it simple.i do appreciat the help.
Re: test fit car,trailer today. [Re: Diego_Ted] #366492
07/05/09 11:16 AM
07/05/09 11:16 AM
ELYRIA,OH
ELYRIA,OH
Diego
thanks.i think.
crazy?maybe.untel you have walked in my shoes you may not understand.to each there own way.
determined yes.to do it the way i want.
Re: test fit car,trailer today. [Re: blownzoom440] #366493
07/05/09 11:24 AM
07/05/09 11:24 AM
San Diego
formula S Offline
formula S  Offline
San Diego
PROBLEM SOLVERS
You can lead a horse to water but you cant make him drink. Take the good advice and get a winch, Diego got his from harbor frieght, I think it is an 8000# for around 300.00 its working great no problems.
Re: test fit car,trailer today. [Re: formula S] #366494
07/05/09 11:38 AM
07/05/09 11:38 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Mike I have a Superwinch 4500 just sitting here, you're welcome to use it til I get my trailer, which could possibly take a couple months as I have to sell my 91 Firebird and then special order the trailer. Let me know, only takes 2 bolts to bolt it down.
Re: test fit car,trailer today. [Re: formula S] #366495
07/05/09 11:38 AM
07/05/09 11:38 AM
ELYRIA,OH
ELYRIA,OH
i am not looking for some1 to change my mine.thank you for your time anyways.
Re: test fit car,trailer today. [Re: ProSport] #366496
07/05/09 11:43 AM
07/05/09 11:43 AM
ELYRIA,OH
ELYRIA,OH
thanks for the offer Bob but i will only get out maybe 2/3 times this yr.nobox and the mopar finals at norwalk and a points meet or T&T there.
your offer is ver kind!
Re: test fit car,trailer today. [Re: blownzoom440] #366497
07/05/09 12:22 PM
07/05/09 12:22 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
I picked up a 2000 lb winch from Tractor Supply for $100. Battery, $80. Works great!
tractor suply huh. my car weighs 4,000lbs but it took minimum force to wench it in.if i get a splitter pulley i can double the pulling by increasing the ratio.
You wont need a 4000# winch to pull your car onto the trailor. As you found out it took some minimal force to pull your car up that very gradual incline of your encloseds ramp. It probably took less then 500# of force.
Your boat hand crank will work fine. It will just take more effort.
You by far Dont have to buy a $500 dollar winch setup.
I bought a HF 2000# winch on sale for $39 bucs that worked great for winching my #3000 ride up Steep ramps. It even pulled a couple of #4500 plus rides up onto my trailor too with a little Human assist.
The same winches sell for $49 now. After years of great easy use I gave it to a friend. I up graded to a #3500 $89 winch. Its alot stronger but it Sucks. If you dont keep tension on the cable during unwind, the cable unspools itself and Jams.
I wish I had my $39 winch back Your type Hand crank sells for $20 bucs at HF. The one you have is free.
Congrats on the new enclosed it looks nice. I love the diamond plate. mike
Re: test fit car,trailer today. [Re: Sport440] #366498
07/05/09 01:05 PM
07/05/09 01:05 PM
ELYRIA,OH
ELYRIA,OH
Thanks Mike! i love the diamond plate also.i got it in just in time to move my daughter and 2 grand kids from florida to ohio in it last month.by the way i got the boat winch for free.some1 threw it out new in the box.single gear 1200lb but it will do the job.with it also i can put 50ft of cable on and just keep cranking instead of rowing with the comealong.
Re: test fit car,trailer today. [Re: blownzoom440] #366499
07/05/09 01:23 PM
07/05/09 01:23 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Why not just drive it in and climb out the window? That's what I do.
Re: test fit car,trailer today. [Re: WILD BILL] #366500
07/05/09 01:28 PM
07/05/09 01:28 PM
ELYRIA,OH
ELYRIA,OH
ya and you are built like a ferret.
Re: test fit car,trailer today. [Re: blownzoom440] #366501
07/05/09 01:41 PM
07/05/09 01:41 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Lay off the Jungle Juice then
Re: test fit car,trailer today. [Re: WILD BILL] #366502
07/05/09 01:52 PM
07/05/09 01:52 PM
ELYRIA,OH
ELYRIA,OH
is that your secret? i am doing what i can not to gain#'s and have lost 8 in the last few months.i will keep working at it.
good luck this week racing.
Re: test fit car,trailer today. [Re: WILD BILL] #366503
07/05/09 02:01 PM
07/05/09 02:01 PM
Rather be in Fallon, Nevada
RussW Offline
super gas
RussW  Offline
super gas
Man I must be doing something wrong, I drive mine all the way in and get out the door , I'm only 6'2" 350+. 04 Pace Shadow 28 ft. I do remove the swing out bar first though.
Re: test fit car,trailer today. [Re: RussW] #366504
07/05/09 02:34 PM
07/05/09 02:34 PM
ELYRIA,OH
ELYRIA,OH
i have not tried getting in/out yet.with the angle of the door and the door bar[not moveable]i am sure it will be a sight.i am 6'2" 230#.i will give it a try this week.
Re: test fit car,trailer today. [Re: blownzoom440] #366505
07/05/09 03:07 PM
07/05/09 03:07 PM
Az
Crizila Offline
Crizila  Offline
Az
Don't forget to set the tongue weight. Should be between 10 and 15% of the gross trailer weight. You will be a happier driver with it closer to 15%.
Fastest 300
Re: test fit car,trailer today. [Re: blownzoom440] #366506
07/05/09 03:22 PM
07/05/09 03:22 PM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
Stationary lexan windows. I drive mine in close to the left side. I then crawl over to the right door and stick my left foot out over the bar. I can then squeeze out the right door. Not difficult at all and sure beats the contortionists positions I can't get into anymore trying to go out the left side.
Re: test fit car,trailer today. [Re: Crizila] #366507
07/05/09 03:56 PM
07/05/09 03:56 PM
ELYRIA,OH
ELYRIA,OH
i am not sure how to get it close but i measured from my old trailer posession over the wheels,distances.the old 1 was only 20ft including the tongue. so i have 8 more ft pluss the tongue in front.i use load springs on the hitch to help tongue weight.
Re: test fit car,trailer today. [Re: blownzoom440] #366508
07/05/09 06:18 PM
07/05/09 06:18 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
No problem, let me know if you change your mind.
Page 2 of 3 1 2 3
