transbrake solenoid #366097
07/04/09 08:16 AM
07/04/09 08:16 AM
Ohio
Lil Wedge Offline OP
Ohio
Anyone ever have a transbrake solenoid give up on you? Can you hear your solenoid click. Ours quit and I checked power and ground and it works but you have to touch it to feel it and then it is so minor, I had to do it a couple times to be sure. A little weaker feel than a electrical relay. It's an A&A unit with lots of runs. I don't remember ever hearing the solenoid like a lot of my friends,but they have glides. This happened shortly after turning up the line pressure. It wouldn't hold over 3500 rpm,just push out.Checked Pressure and was 140 @2500, I raised it to 175, still didn't hold over 3500, and then shortly after it didn't work at all, no reverse or t- brake
Re: transbrake solenoid [Re: Lil Wedge] #366098
07/04/09 10:32 AM
07/04/09 10:32 AM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
Call Rick @ A&A he is very helpfull, knows what he is talking about!
Plus it's his solenoid. Don
Re: transbrake solenoid [Re: cudadon] #366099
07/04/09 01:01 PM
07/04/09 01:01 PM
Ohio
Ohio
I talked to Rick on Wed. and He suggested I turn up the line pressure and call him back Friday, and I wasn't able to call him back. I don't think the line pressure caused the failure, I think it was coming anyway. I will probably just have to wait till monday and call him. Thanks Dan
Re: transbrake solenoid [Re: cudadon] #366100
07/04/09 01:02 PM
07/04/09 01:02 PM
Ohio
Ohio
By the way, beautiful Bee!!!!
Re: transbrake solenoid [Re: Lil Wedge] #366101
07/04/09 06:36 PM
07/04/09 06:36 PM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
Thanks, Rick is about as customer friendly/tech guy that you could ask for! Don
Re: transbrake solenoid [Re: cudadon] #366102
07/04/09 08:43 PM
07/04/09 08:43 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
the only mopar racers that i know who have had solenoid issues were using Griner brakes. i use to use a TA brake, with the engine off i could hear the solenoid click very easily from the pilots chair. now i have an A&A brake, it's real quiet, even have to gag the cat to hear it.
Re: transbrake solenoid [Re: rebel] #366103
07/04/09 09:00 PM
07/04/09 09:00 PM
Ohio
Ohio
Thanks, I don't remember ever hearing this one either.It is pretty old,has a million runs on it, so I guess everything wears out sooner or later.
Re: transbrake solenoid [Re: Lil Wedge] #366104
07/04/09 09:58 PM
07/04/09 09:58 PM
Wisconsin
Garceau Offline
Garceau  Offline
Wisconsin
Anyone making a CO2 activated solenoid for the mopars yet?
I will let ya all figure out what the advantages of it are - there are 2 main ones.
