rear tire size #366075
07/04/09 06:48 AM
07/04/09 06:48 AM
Penguin Country
moepwr Offline OP
moepwr  Offline OP
Penguin Country
What is the widest rear tire I can use in my 1969 Roadrunner. Normal 8 3/4 rear with new leaf springs and shocks.
1969 Road Runner Bench seat, four speed 1999 Dodge Ram 1500 http://picasaweb.google.com/moeville
Re: rear tire size [Re: moepwr] #366076
07/04/09 10:36 AM
07/04/09 10:36 AM
Penguin Country
moepwr Offline OP
moepwr  Offline OP
Penguin Country
I would like to use 295/60 15s on an 8" rim will it fit under the car.
I know of superbees with 295s. But I have heard dodge and plymouths have different wheel well sizes.
Thanks for any help
Re: rear tire size [Re: moepwr] #366077
07/06/09 11:08 AM
07/06/09 11:08 AM
Penguin Country
moepwr Offline OP
moepwr  Offline OP
Penguin Country
bump for the weekday crew.
What do you guys have under your 69 roadrunners and plymouths
Re: rear tire size [Re: moepwr] #366078
07/06/09 11:15 AM
07/06/09 11:15 AM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
295x60-15? Largest 60 series I've seen is 275x60-15. If they do make a 295, an 8" rim is going to be marginal.
I would think the inner wheel tub for a SB and RR are the same. If it fits one one, should fit the other.
