Lowering question #364858
07/02/09 10:04 PM
07/02/09 10:04 PM
SE Wisconsin
49wayfarer Offline OP
SE Wisconsin
Posted this question on the HAMB. I mocked up my rear with 3" lowering blocks, not low enough. With the blocks I have 9" between the top of the axle and the bottom of the frame. I am going to do a trangulated 4 link, and need to know how much clearance is needed between the axle and frame before I would C-notch the frame. If I C-notch, I might as well narrow it for wider tires. Need to find Dakota lowering spindles, maybe I should have Z'd the front end. Not much will be left of the original frame, should have started from scratch.
Re: Lowering question [Re: 49wayfarer] #364859
07/02/09 11:32 PM
07/02/09 11:32 PM
Tracy CA
rabid scott Offline
"You're Where?"
rabid scott  Offline
"You're Where?"
Tracy CA
Channel it!
Re: Lowering question [Re: 49wayfarer] #364860
07/04/09 11:21 PM
07/04/09 11:21 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
OK, I'm missing something here. If you have 9" between the bottom of the frame and the top of the axle with 3" lowering blocks in place, why do you want to "C notch" the frame?
When you mocked up the rear, did you have weight on the rear springs? (Would probably help to know what you have, guess I'll have to look to find your info.) Unless its sitting way high, I don't see how a 4 link is going to drop it enough to need a C notch, as you already can lower the rear 9" (6" + the 3" lowering blocks you will loose and still leave 3" of clearance) depending on how stiff your springs are and how much load you plan on carrying. Gene
Re: Lowering question [Re: poorboy] #364861
07/05/09 06:00 PM
07/05/09 06:00 PM
moparx Offline
moparx  Offline
3-4" would be enough clearance. i don't see any reason to c-notch with 9" plus
Re: Lowering question [Re: moparx] #364862
07/06/09 09:37 AM
07/06/09 09:37 AM
SE Wisconsin
SE Wisconsin
I have 1949 Wayfarer, the rear mocked up, and with 3" blocks the U bolts are about same as the rim, get a flat and ride on the bolts. The leafs are old, they were once wrapped in cloth and a metal wrap. With the 3" blocks the body is still 9" off the ground. The body is bare, don't know how much it will be brought down with weight other than me standing on the rear. Here is a car similar to mine, that I was going to copy. http://www.jalopyjournal.com/forum/showthread.php?t=223048
Don't know if I want to go quite that low, don't have any interest in a compressor to raise and lower it when parked. Just wasn't sure how much frame travel is needed at minimum.
Re: Lowering question [Re: 49wayfarer] #364863
07/06/09 11:00 PM
07/06/09 11:00 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
If your still using the 49 leaf springs, they will probably flatten out a bunch when you get the load on it. Expect the leafs to be nearly flat once loaded. Pile some weight into the trunk to equal what the gas, seats, and everything else missing will add up to, bounce the rear end up & down a few times, then measure the distance between the top of the axle and the bottom of the frame. You should have about 3" to 4" clearance. Also, while its loaded, check your driveshaft clearance and u joint angles.
If your u-bolts are hanging below the rim surface, you need to cut off the excess, you only need a 1/4" to a 1/2" below the nuts of the u-bolts left after torqueing. Cut them after you are finished doing anything with the u-bolts because sometimes after cutting, they are a bear to remove and reinstall the nuts, if you would need to.
That car pictured on the link to the HAMB would be a pita to drive on the roads around here. Your 3" lowering blocks would be bad enough. Gene
