Always use a new TQ with a new trans unless you know it's spotless. If you want to flush the system go to Walmart and get 2 gal of cheap Dex Merc, unhook your return line from the cooler, get a piece of hose that will reach a drain pan, have someone start the car. IN PARK,( or Neutral on MOPARS) let the fluid run into pan until it spits, shut off engine, refill, start, purge into pan, repeat, until fluid is clean, run till it spits, drop pan, change filter, refill. I just did it to my Olds last night. It will flush out everything. If you want to get REAL anal, raise the back of car and run through the gears. Good Luck.
