Valve spring tool needed #364762
07/02/09 08:02 PM
07/02/09 08:02 PM
Kansas
racincuda Offline OP
Kansas
Does anyone make a good valve spring removal tool ???
Heads are on engine and I hav to remove inner springs for start up & break in and then re-install
With any luck I will only go thru this routine one time
Re: Valve spring tool needed [Re: racincuda] #364763
07/02/09 08:20 PM
07/02/09 08:20 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
What engine and heads?
Re: Valve spring tool needed [Re: Snoopy] #364764
07/02/09 08:31 PM
07/02/09 08:31 PM
Kansas
Kansas
DOH !
Small block with W2 econo heads.
duz econo jus mean harder to find parts for
Re: Valve spring tool needed [Re: racincuda] #364765
07/02/09 08:35 PM
07/02/09 08:35 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
Nevermind...
Re: Valve spring tool needed [Re: 64Post] #364766
07/02/09 08:43 PM
07/02/09 08:43 PM
Land of Lost
flatlinedude Offline
No pulse
No pulse
Land of Lost
I made my own very easily. Old stamped rocker arm ground down in bench grinder. Mounted rocker on spare rocker shaft. Clamped big vice-grips to pushrod side of ground down rocker arm. Pressurized the cylinder. Viola. Cheap is good. Free is better.
Carol: "Wow! He's really fast, isn't he?!" John: "Yeah... but he's stupid."
Re: Valve spring tool needed [Re: flatlinedude] #364767
07/02/09 08:50 PM
07/02/09 08:50 PM
Kansas
Kansas
flatliner if I understand correctly you grind enough off pushrod side to get visegrip clamped on correct ?
Sounds good to me, now if i can just find an old rocker
Re: Valve spring tool needed [Re: racincuda] #364768
07/02/09 09:21 PM
07/02/09 09:21 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Make an air attachment by breaking a spark plug and removing the guts then weld a mail air hose attachment to it. Do cylinders at top of compression. Rap them with brass hammer to loosen keepers and oh yes
take your pick
http://chucker54.stores.yahoo.net/valsprinremt.html
Re: Valve spring tool needed [Re: Dodgem] #364769
07/03/09 12:07 PM
07/03/09 12:07 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Mancininhas the tool as does Summit as long as they have standard rocker bolt downs.My kid has the one for BB and it works slick.I also have the ones that grab the spring and gets screwed tight.They work but takes longer and wouldnt fit with his PB booster.Rocky
Chrysler Firepower
Re: Valve spring tool needed [Re: therocks] #364770
07/04/09 10:12 AM
07/04/09 10:12 AM
scratchnfotraction Offline
I use the one from KD tools
its has a star wheel on it and just crank it down bt turning it
it works with the heads on the engine and is weel made
