Trying to figure out why this fuel log leaks.....
#364510
07/02/09 02:29 PM
07/02/09 02:29 PM
Posts: 2,402 Wichita,KS
Blakcharger440
Wichita,KS
I am trying to figure out why this fuel log that is on my carb continually leaks at the carb fittings. The fittings have aluminum spacers on them at the fuel bowls....which I am kind of suspicious of. I am planning on just taking that fuel log off and putting my old one back on as it didnt leak. Here is a pic of the fuel log on the carb.
Re: Trying to figure out why this fuel log leaks.....
[Re: Blakcharger440]
#364511
07/02/09 07:49 PM
07/02/09 07:49 PM
Posts: 3,285 West Coast, USA
jbc426
West Coast, USA
I had a leak at the same place on the fuel bowl, right where that deadsoft aluminum gasket seals. It turned out to be a small scratch across the face of the seat on the fuel bowl, right where the gasket sits. I dressed it with a small fine file and got it flat and smooth. The leak was fixed.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#364512
07/02/09 08:42 PM
07/02/09 08:42 PM
Posts: 2,327 Glendale, AZ
69L78Nova
Banned. Forever.
Banned. Forever.
Glendale, AZ
I would get rid of the aluminum fittings. Ive had them leak more than once
1969 Nova 454/M21/3.31 Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD 5.0/4R70W/3.55 (Daily driver)
[Re: 69L78Nova]
#364513
07/02/09 10:49 PM
07/02/09 10:49 PM
Blakcharger440
Wichita,KS
I figured that getting rid of those aluminum fittings may help it seal better but it also leaks at the very back of that fuel log where there is an allen screw..and it seems no matter how much I tighten it will leak.
I swapped my old fuel line back onto the carb and fired it back up and it does not leak.
But I would still like to try and make this setup leak free.
[Re: HealthServices]
#364515
07/03/09 02:15 PM
07/03/09 02:15 PM
Blakcharger440
Wichita,KS
Did you use Teflon tape?
Nope, I did not use teflon tape on any of the fuel fittings. I have never used any type of tape or sealant on fuel fittings before.
#364516
07/03/09 03:19 PM
07/03/09 03:19 PM
RapidRobert
As said check the sealing surfaces and can you toss the spacers, seems like there is plenty of room for the log to be closer to the carb wo any ill effects
