Turn signal lights not working??? #364028
07/01/09 09:56 PM
07/01/09 09:56 PM
Indiana
F6F6Dodge Offline OP
Indiana
I have a 72 Demon and the front driver side turn signal light will not light up when the parking lights/running lights are turned on...But the turn signal light will flash when activated....(I have replaced the bulb)
What is going on and what should I look for??? also, I have found a flasher terminal under the dash and replaced it...but I don't know if its for the 4-way flashers or turn signals or if there are 2 separate flasher pods or just one that works for both the turns and the 4-ways?? ANY help would be great!!!! all other lights work fine except the in-dash drivers turn light won't light up either...
Re: Turn signal lights not working??? [Re: F6F6Dodge] #364029
07/01/09 10:02 PM
07/01/09 10:02 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
You probably habre a bad ground at the front socket.
Re: Turn signal lights not working??? [Re: F6F6Dodge] #364030
07/02/09 02:23 PM
07/02/09 02:23 PM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
I agree with stumpy on bad ground on socket.
Also, it's likely the bulb in the dash is burned out, or snap-in socket for the dash bulb is corroded and not making a ground.
Re: Turn signal lights not working??? [Re: MoparMarq] #364031
07/02/09 04:21 PM
07/02/09 04:21 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
Had a similar problem with my 68 B body. It was a bad conection at the coulumn plug.
