I have a 72 Demon and the front driver side turn signal light will not light up when the parking lights/running lights are turned on...But the turn signal light will flash when activated....(I have replaced the bulb)
What is going on and what should I look for??? also, I have found a flasher terminal under the dash and replaced it...but I don't know if its for the 4-way flashers or turn signals or if there are 2 separate flasher pods or just one that works for both the turns and the 4-ways?? ANY help would be great!!!! all other lights work fine except the in-dash drivers turn light won't light up either...
