can anyone cut me a indy valley cover in half?
#363860
07/01/09 08:11 PM
07/01/09 08:11 PM
can anyone cut me a indy RB valley cover in half on a 45 degree identical to a bulldog 2 piece valley cover. i dont have anyone around me to do it for me.please help if you have done one before.
i am waiting to try this 426 hemi indy offset crossram intake out but need a valley cover and i dont want to take off the heads.thanks
Re: can anyone cut me a indy valley cover in half?
#363861
07/01/09 08:18 PM
07/01/09 08:18 PM
Posts: 17,923 Akron, Ohio
ProSport
Akron, Ohio
A local shop cut mine for $50, best $50 I ever spent. I don't have to touch the heads to install or remove the tray.
Re: can anyone cut me a indy valley cover in half? *DELETED*
#363862
07/01/09 08:44 PM
07/01/09 08:44 PM
#363865
07/01/09 09:01 PM
07/01/09 09:01 PM
Posts: 7,348 Mt.Vernon ,Ohio
VernMotor
Mt.Vernon ,Ohio
sure, i'd be happy to do it. no charge whatsoever, i'll even pay the return shipping.
Wow what a great guy ! I thought of you right off the bat !
[Re: B G Racing]
#363868
07/01/09 09:12 PM
07/01/09 09:12 PM
We don't cut them in half,just mill enough of the sides so that it drops between the heads.Just run it on a mill or belt sander till it drops in. We also use the one with the removable center for roller cams,don't have to break the seal at the heads to check the lifters.
BG, do you have provisions to cut one on a 45? how would you get the silicone to stay when you slide it in, doing it your way.
#363869
07/01/09 09:16 PM
07/01/09 09:16 PM
Posts: 3,396 Pa
Hot 340
Pa
Some table bandsaws have the abilitly to tilt the table 45 degrees, just set up a straightedge to guide the plate.
#363870
07/01/09 09:20 PM
07/01/09 09:20 PM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
We can machine anything But the best solution is like I mentioned,mill or sand the sides.You are only taking the narrow part of the champher off the distance at the top that meets the head stays the same and the bead of silicone fills the gap as usual,just make sure you get plenty at the 4 corners,we do tons of them this way.So easy a caveman can do it or even a "Fish Peddler"
[Re: B G Racing]
#363871
07/01/09 09:42 PM
07/01/09 09:42 PM
#363872
07/01/09 10:06 PM
07/01/09 10:06 PM
B G Racing
Eighty Four, PA
id really like the 45 degree cut. can you cut me one and bring it to Beavr Springs,its for the hemi and with my carb linkage kit from indy please. thanks
I could but it doesn't make good sence to me.Cutting it down the middle just add another seam to have leaks and now everytime you want to go into the lifter valley you have to cut 3 longitudnal beads of silicone and the two rails to unglue.Doing it the way I suggest you never have to break the seal and less silicone beads to deal with.Using the removable gasketed center for access to the lifters and still have the ability to remove the entire plate without removing the heads.
[Re: B G Racing]
#363873
07/01/09 10:20 PM
07/01/09 10:20 PM
Posts: 446 oregon
savoyracer
oregon
...............................I stayed at a Holiday Inn last night.
[Re: AndyF]
#363875
07/02/09 07:51 AM
07/02/09 07:51 AM
Posts: 1,973 SoCal
jake4cars
SoCal
Step up to the good stuff!
That'a a cool piece , do you sell them, how much?
Joey
