Page 1 of 3 1 2 3
can anyone cut me a indy valley cover in half? #363860
07/01/09 08:11 PM
07/01/09 08:11 PM
Anonymous OP
Anonymous OP
can anyone cut me a indy RB valley cover in half on a 45 degree identical to a bulldog 2 piece valley cover.
i dont have anyone around me to do it for me.please help if you have done one before.
i am waiting to try this 426 hemi indy offset crossram intake out but need a valley cover and i dont want to take off the heads.thanks
Re: can anyone cut me a indy valley cover in half? #363861
07/01/09 08:18 PM
07/01/09 08:18 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
A local shop cut mine for $50, best $50 I ever spent. I don't have to touch the heads to install or remove the tray.
Re: can anyone cut me a indy valley cover in half? *DELETED* #363862
07/01/09 08:44 PM
07/01/09 08:44 PM
Anonymous OP
Anonymous OP
Post deleted by Eric
Re: can anyone cut me a indy valley cover in half? #363863
07/01/09 08:48 PM
07/01/09 08:48 PM
Arlington, Texas
earlybee Offline
earlybee  Offline
Arlington, Texas
Re: can anyone cut me a indy valley cover in half? #363864
07/01/09 08:49 PM
07/01/09 08:49 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I don't know about the Hemi. But on a wedge you can cut the sealer with a Knife below the heads. Then you slide the tray back and drop it down into the valley. Tilt it and it will come out. I tapped the middle holes 3/8" in the end of the tray so I could screw long bolts in to use as handles.
Doug
Re: can anyone cut me a indy valley cover in half? #363865
07/01/09 09:01 PM
07/01/09 09:01 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
sure, i'd be happy to do it. no charge whatsoever, i'll even pay the return shipping.
Wow what a great guy ! I thought of you right off the bat !
Re: can anyone cut me a indy valley cover in half? [Re: dvw] #363866
07/01/09 09:01 PM
07/01/09 09:01 PM
In The Hills
jughed Offline
jughed  Offline
In The Hills
if you cut it in two, have it cut an inch or so from either side.
you can remove the larger piece to make it easier to get to the lifters.
Re: can anyone cut me a indy valley cover in half? [Re: jughed] #363867
07/01/09 09:08 PM
07/01/09 09:08 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
We don't cut them in half,just mill enough of the sides so that it drops between the heads.Just run it on a mill or belt sander till it drops in. We also use the one with the removable center for roller cams,don't have to break the seal at the heads to check the lifters.
Re: can anyone cut me a indy valley cover in half? [Re: B G Racing] #363868
07/01/09 09:12 PM
07/01/09 09:12 PM
Anonymous OP
Anonymous OP
BG, do you have provisions to cut one on a 45?
how would you get the silicone to stay when you slide it in, doing it your way.
Re: can anyone cut me a indy valley cover in half? #363869
07/01/09 09:16 PM
07/01/09 09:16 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Some table bandsaws have the abilitly to tilt the table 45 degrees, just set up a straightedge to guide the plate.
Re: can anyone cut me a indy valley cover in half? #363870
07/01/09 09:20 PM
07/01/09 09:20 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
We can machine anything But the best solution is like I mentioned,mill or sand the sides.You are only taking the narrow part of the champher off the distance at the top that meets the head stays the same and the bead of silicone fills the gap as usual,just make sure you get plenty at the 4 corners,we do tons of them this way.So easy a caveman can do it or even a "Fish Peddler"
Re: can anyone cut me a indy valley cover in half? [Re: B G Racing] #363871
07/01/09 09:42 PM
07/01/09 09:42 PM
Anonymous OP
Anonymous OP
id really like the 45 degree cut.
can you cut me one and bring it to Beavr Springs,its for the hemi and with my carb linkage kit from indy please. thanks
Re: can anyone cut me a indy valley cover in half? #363872
07/01/09 10:06 PM
07/01/09 10:06 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
I could but it doesn't make good sence to me.Cutting it down the middle just add another seam to have leaks and now everytime you want to go into the lifter valley you have to cut 3 longitudnal beads of silicone and the two rails to unglue.Doing it the way I suggest you never have to break the seal and less silicone beads to deal with.Using the removable gasketed center for access to the lifters and still have the ability to remove the entire plate without removing the heads.
Re: can anyone cut me a indy valley cover in half? [Re: B G Racing] #363873
07/01/09 10:20 PM
07/01/09 10:20 PM
oregon
savoyracer Offline
savoyracer  Offline
oregon
...............................I stayed at a Holiday Inn last night.
Re: can anyone cut me a indy valley cover in half? #363874
07/02/09 01:16 AM
07/02/09 01:16 AM
AndyF Offline
AndyF  Offline
Step up to the good stuff!
Re: can anyone cut me a indy valley cover in half? [Re: AndyF] #363875
07/02/09 07:51 AM
07/02/09 07:51 AM
SoCal
jake4cars Offline
jake4cars  Offline
SoCal
That'a a cool piece , do you sell them, how much?
Joey
Re: can anyone cut me a indy valley cover in half? [Re: jake4cars] #363876
07/02/09 08:08 AM
07/02/09 08:08 AM
Wellington, FL
cudabunch Offline
cudabunch  Offline
Wellington, FL
I cant see why you want one cut when you can buy one from Andy or Indy.I have the Indy one and it works great, no leaks.
Re: can anyone cut me a indy valley cover in half? [Re: ProSport] #363877
07/02/09 10:12 AM
07/02/09 10:12 AM
Connecticut
5126brl No more Offline
Connecticut
You would think that since Indy killed bulldog they would have started making the 2 piece cover?
Re: can anyone cut me a indy valley cover in half? [Re: jake4cars] #363878
07/02/09 10:53 AM
07/02/09 10:53 AM
AndyF Offline
AndyF  Offline
You can get those billet valley plates from Mancini Racing, Hughes Engines, etc. Part number is AR182. They come with a gasket but they are also machined for an o-ring if you want to go that way. RB only though. There isn't a version for the B motor.
Re: can anyone cut me a indy valley cover in half? [Re: AndyF] #363879
07/02/09 11:47 AM
07/02/09 11:47 AM
fullmetaljacket Offline
I ran the Hughes steel two piece unit and it sealed flawlessly. Just have to be patient and precise in order to get a good seal. I also used the aluminum raised bar stock to make up the distance created by the SR heads.
Page 1 of 3 1 2 3
