Correct weight oil to use in a 1948 New Yorker? #363672
07/01/09 02:14 PM
07/01/09 02:14 PM
Beertown, WI
Slingshot Offline OP
Beertown, WI
I have a '48 New Yorker straight 8 flathead and need to know what weight of oil I can use. The shop manual calls for 30W, but can i use anything else? It has high miles from what I know... Any thoughts?
Do you angle park in a parallel universe?
NHRA Division 3 Announcer
Great Lakes Dragaway
DJ-Saturday Morning Cartunes/The Gearhead Show
6-9a.m. Saturday mornings
WMSE Milwaukee 91.7fm
www.wmse.org
Re: Correct weight oil to use in a 1948 New Yorker? [Re: Slingshot] #363673
07/01/09 02:26 PM
07/01/09 02:26 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Id run straight 30 if you can find it.Most is non detergent.If not try 20w40.Rocky
Chrysler Firepower
Re: Correct weight oil to use in a 1948 New Yorker? [Re: therocks] #363674
07/01/09 02:37 PM
07/01/09 02:37 PM
Beertown, WI
Beertown, WI
Right on. Thanks!!
www.wmse.org
Re: Correct weight oil to use in a 1948 New Yorker? [Re: therocks] #363675
07/01/09 02:38 PM
07/01/09 02:38 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
In summer you can go up to 40w without any problem.
Re: Correct weight oil to use in a 1948 New Yorker? [Re: stumpy] #363676
07/01/09 02:53 PM
07/01/09 02:53 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Id say 10w30 or if worried 20w50 would even work.Just have to be careful because if its sludged from non detergent oil it will break it loose.Those rab non det.Probally already has had det oil in it though as non is kind of hard to find.Rocky
Chrysler Firepower
