Finally Dynoed the New Sig Car Bullet ! #363579
07/01/09 12:07 PM
07/01/09 12:07 PM
Renton, Wa.
Classof70Chally Offline OP
super gas
super gas
Renton, Wa.
I went to a local speed shop here yesterday and strapped the vert down on a chassis dyno. I did three pulls and they were all nearly identical. The best one showed a max RWHP of 380 @ 5,250 pm and a max RW torque of 460 ftlbs @ 3,250 rpm. This is nearly 100 RWHP above my previous motor that was in the car when I bought it. Overall I was pleased with the numbers considering it is a mild to medium build with manifolds for the street. The operator estimated my crank HP at around 450. He said for comparison he has had several new Challenger SRT8's (6.1L) on his machine and they come in at about 340rwhp. Thanks to those here that helped with their expertise and info for my build!
Re: Finally Dynoed the New Sig Car Bullet ! [Re: Classof70Chally] #363580
07/01/09 08:02 PM
07/01/09 08:02 PM
Renton, Wa.
super gas
super gas
Renton, Wa.
BTTP
Re: Finally Dynoed the New Sig Car Bullet ! [Re: Classof70Chally] #363581
07/01/09 08:36 PM
07/01/09 08:36 PM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
very nice...
Re: Finally Dynoed the New Sig Car Bullet ! [Re: Quicksilver440] #363582
07/01/09 08:44 PM
07/01/09 08:44 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Thats good RWHP #'s. Tell us your build againg as I dont remember it all. Ron
Re: Finally Dynoed the New Sig Car Bullet ! [Re: 383man] #363583
07/02/09 12:28 AM
07/02/09 12:28 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Ive followed your progress but dont remember it all myself. Share it again please Congrats on the numbers. mike
Re: Finally Dynoed the New Sig Car Bullet ! [Re: Classof70Chally] #363584
07/02/09 12:59 AM
07/02/09 12:59 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Nice
Are the numbers uncorrected or corrected RWHP?
What type of Chassis Dyno?
I know DynoJet lets anyone download their winPEP 7 software, so if you have the dyno operator E-mail you the run files you can display the information in several formats and with different correction factor types with the software.
Re: Finally Dynoed the New Sig Car Bullet ! [Re: 451Mopar] #363585
07/02/09 11:13 AM
07/02/09 11:13 AM
Renton, Wa.
super gas
super gas
Renton, Wa.
Thanks guys. The dyno was a Mustang and the tech told me it is conservative by about 15%. So those numbers are corrected up, the actual reading was 340 rwhp. My build is a 440 .030 over, diamond flat tops at zero deck on 440 Source tapered I-beam rods, 440 Source heads with what I would call a 'stage one' port job, cam is a Comp retro hyd roller #23-710-9 which has 224int/230ex @ .050 duration with .538int/.534ex lift and 110' lobe seperation. The intake is stock six pack with Promax prepped carbs, HP ex manifolds and 2.5 ex all the way back with muffs and resonators. Static comp ratio is 10.0 to 1 with .043 quench distance and about 190 psi cyl pressure. I'm running a TKO 600 5 spd behind it with a Dana 3.54. It pulls hard from about 1,500 rpm all the way to 6,000 where it hits the rev limiter. I know I could do better with some headers but I like the stock look and show the car often. The tech told me he thought it was a good motor considering I'm running manifolds.
