Electronic Ignition/Voltage Regulator
#363464
07/01/09 10:49 AM
07/01/09 10:49 AM
Posts: 3,287 Stroudsburg, PA
Erik
Stroudsburg, PA
Can a '68 regulator be used w/ electronic ignition? I would think it can't, but I want to make sure.
1970 Challenger Convertible soon to be T/A convertible
Contrary to the opinions of some, I am not dumber than I look.
Re: Electronic Ignition/Voltage Regulator
[Re: superbeedave]
#363468
07/07/09 08:52 PM
07/07/09 08:52 PM
Posts: 1,822 Colorado
denfireguy
Colorado
I have read many times that if you install electronic ignition in the 69 and older cars that you must convert to 70's and up charging system. That would mean dual field alt. with regulator change and the pigtail for regulator. 69 and older points style charging system just doesn't supply enough voltage for ignition/electrical when converting to electronic ign.
I am not sure why you would have to. The only possible reason is to clean up the power bumps that mechanical regulators are known for. If you get a solid state replacement regulator that looks like the older one, I would go that route. Just looks better to me in a matching number car in my opinion. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: Erik]
#363469
07/07/09 10:02 PM
07/07/09 10:02 PM
Posts: 18,414 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
The charging system has nothing to do with the ignition system. So to better answer your question yes you can use the 68 charging system with electronic ignition.
[Re: NITROUSN]
#363470
07/08/09 01:04 PM
07/08/09 01:04 PM
Posts: 10,204 Someplace you aren't
SomeCarGuy
My car worked fine with the old style reg. I noticed no difference when I went to the new style VR. I only did so becasue that was the way the new engine harness was set up.
I want my fair share
[Re: NITROUSN]
#363475
07/10/09 12:53 AM
07/10/09 12:53 AM
denfireguy
Colorado
I have only seen that happen once. 99% of the time, the emitter junction on the pass transistor fails, opening the circuit and no charge occurs. If it did stick on, just unplug the regulator connector or either field wire and limp home. I fished an old black with yellow lettering regulator and a Kmart/Penske ignition module out of the trunk extension area where I kept them in case of a failure on the road. Been there for 28 years undisturbed and forgotten.
