A727 Shifter seal
#36294
05/03/07 07:55 PM
05/03/07 07:55 PM
Hi folks, I got a leaking seal where the shifter shaft goes into my A727 trans. Is it as simple as dropping the pan and removing the valve body, then R&R the seal and reassemble? I just don't want to take things appart and then find out I'm over my head. Thanks
Re: A727 Shifter seal
#36295
05/03/07 08:25 PM
05/03/07 08:25 PM
Posts: 25,794 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Some folks manage to change the seal without R&Ring the VB but I think it's best to remove it.
Just drive out the old seal and use a stack of washers and a bolt/nut to pull the new seal into position.
#36297
05/04/07 05:14 AM
05/04/07 05:14 AM
Thanks guy's! If I do remove the VB, are there any step's of caution or concern? I'm comfortable with external repairs, but even light internal's are not my bag. I'm not seeking a through step by step explanation, but if there is something to watch out for, (flying springs, etc.) any tips would be greatly apperciated. Thanks again & enjoy the weekend!
[Re: JohnRR]
#36299
05/04/07 09:25 AM
05/04/07 09:25 AM
Posts: 5,443 Indiana
YO7_A66
Indiana
You might want to back out the neutral safety switch a few turns too to keep it from damaging the contact on the VB.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
#36300
05/04/07 02:22 PM
05/04/07 02:22 PM
John_Kunkel
Rio Linda, CA
Also, before you remove the VB, place the shifter in Park and turn the driveshaft until you hear the pawl click into place, then place the shifter in "1"; this makes the park rod easier to remove/install in the tail.
[Re: John_Kunkel]
#36301
05/04/07 05:15 PM
05/04/07 05:15 PM
Andrewh
tool kd tool sells the seal remover and installer. Only catch was needed a c-clamp to put enough down force to get a bite on the seal. Works pretty well and didn't need to drop the pain again.
#36302
05/04/07 08:35 PM
05/04/07 08:35 PM
Check the shaft also. Mine was so grooved I had to change it also. It is a very high mileage tranny though.
