A727 Shifter seal #36294
05/03/07 07:55 PM
05/03/07 07:55 PM
Anonymous OP
Anonymous OP
Hi folks, I got a leaking seal where the shifter shaft goes into my A727 trans. Is it as simple as dropping the pan and removing the valve body, then R&R the seal and reassemble? I just don't want to take things appart and then find out I'm over my head.
Re: A727 Shifter seal #36295
05/03/07 08:25 PM
05/03/07 08:25 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Some folks manage to change the seal without R&Ring the VB but I think it's best to remove it.
Just drive out the old seal and use a stack of washers and a bolt/nut to pull the new seal into position.
Re: A727 Shifter seal [Re: John_Kunkel] #36296
05/03/07 08:38 PM
05/03/07 08:38 PM
Ontario, Canada
78D150CLUB Offline
My avatar is a self portrait!!
78D150CLUB  Offline
Ontario, Canada
I did change the seal in mine without removal, but it's a nightmare to try and line the seal up AND drive it into place on the top of the case, espscially with little to no room in the trans tunnel above to tap a socket. Next time, I'll be pulling the body to change one. Much easier to pull it in as John said.
I want to die like my Grampa, peacefully, in his sleep. Not screaming in terror like his passengers.
Re: A727 Shifter seal #36297
05/04/07 05:14 AM
05/04/07 05:14 AM
Anonymous OP
Anonymous OP
Thanks guy's! If I do remove the VB, are there any step's of caution or concern? I'm comfortable with external repairs, but even light internal's are not my bag. I'm not seeking a through step by step explanation, but if there is something to watch out for, (flying springs, etc.) any tips would be greatly apperciated. Thanks again & enjoy the weekend!
Re: A727 Shifter seal #36298
05/04/07 09:10 AM
05/04/07 09:10 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
there is a spring with the accumulator piston that will fall out when you drop the valve body , its over where the 4 bolts in a circle are , piston goes in first , spring against the VB .
also make note , the VB bolts on require 75 INCH POUNDS of torque , they strip real easy .
other than dealing with the park rod its pretty easy .
Re: A727 Shifter seal [Re: JohnRR] #36299
05/04/07 09:25 AM
05/04/07 09:25 AM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
You might want to back out the neutral safety switch a few turns too to keep it from damaging the contact on the VB.
Re: A727 Shifter seal #36300
05/04/07 02:22 PM
05/04/07 02:22 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Also, before you remove the VB, place the shifter in Park and turn the driveshaft until you hear the pawl click into place, then place the shifter in "1"; this makes the park rod easier to remove/install in the tail.
Re: A727 Shifter seal [Re: John_Kunkel] #36301
05/04/07 05:15 PM
05/04/07 05:15 PM
Andrewh Offline
Andrewh  Offline
tool
kd tool sells the seal remover and installer.
Only catch was needed a c-clamp to put enough down force to get a bite on the seal. Works pretty well and didn't need to drop the pain again.
Re: A727 Shifter seal #36302
05/04/07 08:35 PM
05/04/07 08:35 PM
Anonymous OP
Anonymous OP
Check the shaft also. Mine was so grooved I had to change it also. It is a very high mileage tranny though.
