Symptoms of a coil going bad? #362532
06/30/09 11:20 AM
06/30/09 11:20 AM
mikemotorhead Offline OP
super street
super street
Can a coil going bad give me a intermittant high rpm(6500) miss?
Thanks Mike
Re: Symptoms of a coil going bad? [Re: mikemotorhead] #362533
06/30/09 07:05 PM
06/30/09 07:05 PM
Minn
SportF Offline
SportF  Offline
Minn
Yes. Intermitant miss, intermitant start and run ok, then quit and not start. Missing at any or all the time is certainly a possiblity. It can be very fustrating. You need a spare coil as a tool to install just to see if problems go away. I have checked them with a meter and got passing results only to have them quit later. I have seen poor resistance readings, but seem to run ok. Heat is a factor for working/not working. I pulled my coil wire at the distributor once to check the connection and there was oil dripping out of the wire coming from the coil. Like I said, you really should have a coil to use as a spare.
Re: Symptoms of a coil going bad? [Re: SportF] #362534
06/30/09 07:58 PM
06/30/09 07:58 PM
St Paul MN
73swinger Offline
73swinger  Offline
St Paul MN
I agree, I now carry a spare coil, and I also mounted a second ECU within connection reach of my regular one.
Heat was also a factor with my coil.
Chris Schwartz 73 Swinger 340 12.451 @ 108.78 73 Gold Duster, needs a plan.
Re: Symptoms of a coil going bad? [Re: 73swinger] #362535
06/30/09 08:01 PM
06/30/09 08:01 PM
Great Lakes Region
abodiesonly1 Offline
Great Lakes Region
Yes....I just had to return a brand new MSD coil for a high rpm miss.
Re: Symptoms of a coil going bad? [Re: abodiesonly1] #362536
07/01/09 11:00 AM
07/01/09 11:00 AM
super street
super street
Thanks for the replys
Mike
