727 Questions #362441
06/30/09 09:24 AM
06/30/09 09:24 AM
U.S.
moparniac Offline OP
U.S.
Aluminum Drum or CSR Carbon fiber shield?
whats the difference between 5.0/4.2 kick down levers?
Mopar Performance
Re: 727 Questions [Re: moparniac] #362442
06/30/09 09:26 AM
06/30/09 09:26 AM
Stockholm, Sweden
MrSixpack Offline
MrSixpack  Offline
Stockholm, Sweden
Why not both, I have both for safty.
Now day's we only use the 4.2, with the 5.0 there is an overlap when shifting gears.
1970 Super Stock Challenger ex. Paul Rossi
1968 Dodge Dart GT 340
1968 Dodge Charger /6 3 speed manual
1966 Chrysler 300 Loaded
1968 Dodge Charger R/T 440
1968 Mini Cooper
Re: 727 Questions [Re: moparniac] #362443
06/30/09 09:28 AM
06/30/09 09:28 AM
an8sec70cuda Offline
BOTH. For a street car I'd use the steel drum. Mine is the A&A piece, very nice. After my explosion last fall, I'll never drive another car w/o a shield or blanket of some sort on it. I have the CSR shield on mine and had one on it when the trans exploded...it kept my feet attached to my legs.
On the kickdown levers, I don't know. I never bothered to ask my trans builder what he put in it. Maybe someone who knows more about them will answer that for you. CHIP
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 727 Questions [Re: an8sec70cuda] #362444
06/30/09 10:20 AM
06/30/09 10:20 AM
U.S.
U.S.
I had the CSR on my chally...... Excellent piece
Just wondering if its worth the extra coin to get the drum also!
Mopar Performance
Re: 727 Questions [Re: moparniac] #362445
06/30/09 10:29 AM
06/30/09 10:29 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
the kickdown lever really depends on the valve body manufacturer and what they recomend for your application - Griner suggests a 3.2 or 3.8
Read this - it will answer alot of questions you might have - 8 pages
727 Built right
Re: 727 Questions [Re: moparniac] #362446
06/30/09 10:41 AM
06/30/09 10:41 AM
organ
maximum entropy Offline
organ
billet steel drum and a blanket here also. as far as the k/d lever, the number indicates the ratio of the lever. a 5.0 lever is 5:1, which means it takes a longer stroke of the servo to apply, but it holds with more force. it's also slower to release. it's a trade-off like everything else. always use the lever recommended by the manufacturer of your valve body or shift kit/ trans kit.
Re: 727 Questions [Re: moparniac] #362447
06/30/09 10:50 AM
06/30/09 10:50 AM
The shield has to be there to pass tech inspection at the track and will keep the trans explosion contained. You NEED the good drum. If you don't put it in now, you will regret it... I know I did. Even with the good drum in it, you should still put a shield on it. Anything can break, but like I said, the shield is mandatory if you're gonna race at a track that has tech inspections. CHIP
CHIP
Re: 727 Questions [Re: an8sec70cuda] #362448
06/30/09 11:08 AM
06/30/09 11:08 AM
U.S.
U.S.
thx ill just get both.... also chip im gonna get another converter from your guy... I liked the one in my chally
Mopar Performance
Re: 727 Questions [Re: moparniac] #362449
06/30/09 01:25 PM
06/30/09 01:25 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Hands down the A+A drum and don't use the 5.0 lever , either a 3.8 or 4.2 , also get the HD band strut .
Re: 727 Questions [Re: DJVCuda] #362450
06/30/09 08:45 PM
06/30/09 08:45 PM
NC
440Jim Offline
440Jim  Offline
NC
I have a Griner valve body and I run a 3.8 lever and 5 clutch front drum (aluminum of course), plus the shield (required safety equipment). I recommend both, but the drum (aftermarket steel or aluminum) is the most important, but the shield is required by rule (and good idea).
Re: 727 Questions [Re: 440Jim] #362451
06/30/09 09:02 PM
06/30/09 09:02 PM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
the more pressure you run, the less lever you need - according to Steve Griner.
Wedgie - click that link I posted in my last post - John Cope of CRT helped me with a very informative article you would get alot out of.
Re: 727 Questions [Re: moparniac] #362452
07/01/09 01:36 PM
07/01/09 01:36 PM
Cool! Dave's a good guy and builds some awesome converters. Stands behind his work too. CHIP
CHIP
Re: 727 Questions [Re: an8sec70cuda] #362453
07/01/09 04:12 PM
07/01/09 04:12 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
AFAIK the 5.0 lever was designed for the hemi transmission. It has its own special setup, and is not used for any application but that.
Re: 727 Questions [Re: RemCharger] #362454
07/01/09 04:44 PM
07/01/09 04:44 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
A lot of the stuff that was considered de rigueur in the sixties has dropped out of favor; the "Hemi only" lever, wide band, and wide drum didn't really do what they were expected to do compared to modern thinking.
