Trans Shield Installation #362289
06/30/09 02:59 AM
06/30/09 02:59 AM
North Carolina
CALSDART Offline OP
CALSDART  Offline OP
North Carolina
What is the easist way to install a trans shield in a stock floor A body Dart without cutting up the entire floor tunnel
Calvin Thompson
Re: Trans Shield Installation [Re: CALSDART] #362290
06/30/09 03:59 AM
06/30/09 03:59 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
buy a CSR carbon fiber sheild, hammer the pinch weld on the firewall tunnel area flat & squeeze the trans & mounted sheild back into place. it's a tight fit but it works.
Re: Trans Shield Installation [Re: rebel] #362291
06/30/09 06:36 AM
06/30/09 06:36 AM
St. Louis Mo.
10 o to go Offline
"Happy Don"
10 o to go  Offline
"Happy Don"
St. Louis Mo.
also cut those aluminum ears off trans bellhousing .If running transbrake drill hole for vent.
I put prefitted braided line for and have them on trans before going up and shifter cable bracket on only.
Sometimes depending on cars firewall is what type of tool to put bolts in tilt engine back its just different on each car .
don
2009 418" build dan smith built new 9.96 131.82 6.23 108 1.30 60 foot best to date 9/15/09 8in 727 430 dana 2860 lb 3040 lb w driver
Re: Trans Shield Installation [Re: 10 o to go] #362292
06/30/09 08:56 AM
06/30/09 08:56 AM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
Cut off the ears, I have a CSR, Small Block with a 904 in a 68 Dart and it still fits tight I cut holes in the firewall to access the bolts it makes it a lot easier. I made removable plates to cover the holes.
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
