Re: Rebuilding a Hydro-locked New Hemi
[Re: bohmer2]
#361751
06/29/09 08:58 PM
06/29/09 08:58 PM
Posts: 1,607 Lapeer, MI.
todd440
Lapeer, MI.
If pieces got into the combustion side of the piston, then debris got into the intake. I'd be cleaning the he@@ out of that intake, with brake cleaner and compressed air, then repeat. Once in the intake, it will travel to other cylinders also.
[Re: todd440]
#361752
06/29/09 10:07 PM
06/29/09 10:07 PM
Posts: 1,828 houston texas
gremlinsteve
houston texas
i have take out rods and pistons from stoker builds also. let me know if you need/want em...
like said..that intake manifold will hold on to things. i would look at the heads and the piston tops. see if there is obvious damage that can be seen. pitting or small strokes from parts swapping cyl is not uncommon for them when they go.
most just swap out the intake for new ones..
the 5.7 piston is weakest around the top ring land. real thin and they have a tendency of breaking off.
if You Like Gremlinsteve. Gremlinsteve Likes You.
[Re: bohmer2]
#361754
06/30/09 01:09 AM
06/30/09 01:09 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
shouldn't affect the balance of the crank, other than the new parts you buy to replace the old ones.
I suppose it could have cracked the crank, but it sounds like the rod gave up the ghost before any other parts did.
**Photobucket sucks**
[Re: 70Cuda383]
#361755
06/30/09 09:32 AM
06/30/09 09:32 AM
gremlinsteve
houston texas
heck..ive got stock and forged cranks laying around....
steve
[Re: gremlinsteve]
#361756
06/30/09 11:55 AM
06/30/09 11:55 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
hmm....what's the front end of the crank snout look like? wonder if you could use one to make a low budget LA 318/349 stroker....
