cam suggestions for 440
#359953
06/27/09 08:02 PM
06/27/09 08:02 PM
Posts: 2,295 dark side of the moon
Dougsmopars
I bought this 68 GTX with 440 automatic. It has a 750 double pumper which i'm going to replace with an Edelbrock 800 Thunder series. It has a racer brown cam in it of unknown specs. Very lumpy idle. Very poor vacuum. Way too much cam. Motor was rebuilt about 5000 miles ago according to previous owner. Has Torker intake Mopar ignition with orange box and headers. I'm looking for a good cam that will be very torque on bottom end. Something will make plenty of power from around 1500 to 5500 RPM. Would like to be able to put the power breaks back in the car. I made this mistake before installing to big a cam for a basically stock motor. I put a mopar 509 purple shaft in my Road Runner with 440 six pack 4 speed. It made less power then with stock cam. Any of you guy's have any suggestions? I was looking at some of the Lunati VOODO cams? Any thoughts? I want to keep it hydraulic.
Re: cam suggestions for 440
[Re: Dougsmopars]
#359954
06/27/09 08:05 PM
06/27/09 08:05 PM
Posts: 565 IA
landon1
IA
i looked at the voodoo cams, but i don't think too many people are running them in 440s - don't hear too much about them anyhow. i went with Comp XE 268. power in the same range you're looking for (basic street range). mine is not installed (still waiting on my block at the machine shop).
'71 Satellite Sebring 440
[Re: Dougsmopars]
#359955
06/27/09 08:08 PM
06/27/09 08:08 PM
Posts: 1,216 Fresno, CA
cudamank
Fresno, CA
I run the Voodoo 60303, 440, .030 over, 10.5, 3400 stall, performer intake, 750 speed demon nice idle, still plenty of vacuum for my brakes.
[Re: Dougsmopars]
#359959
06/27/09 09:29 PM
06/27/09 09:29 PM
Posts: 2,069 Renton, WA
GreenBlurr
super gas
super gas
Renton, WA
You could start by NOT undercarbing your 440 like too many people on here seem to do. A holley 750 is nowhere near enough for that motor with that kind of cam....especially if it still has the same jetting it came with out of the box. And an edelbrock 800 will not be a step in the right direction either. Sure, they have good just off idle response in their accelerator shot, but they are lean as heck form there out becuase they do not hold any danged fuel.
You need a holley 850 double pumper for that motor that is properly jetted and fitted with squirters and eccelerator pump cams to compliment said jetting. You will not recognize the motor in the world of difference in its runability and performance.
[Re: DAYCLONA]
#359963
06/27/09 10:00 PM
06/27/09 10:00 PM
Posts: 21,085 Niles , Ohio
therocks
Niles , Ohio
For a decent cam for a driver I had luck with Summits big cam kit.Racy type idle pulls strong good vacuum and all around good for a streeter.One is still running in a 383 after 20 years.Id run a Holley Street Dominator with an 850 Holley.Rocky
Chrysler Firepower
[Re: Dougsmopars]
#359967
06/27/09 11:08 PM
06/27/09 11:08 PM
Posts: 18,160 Mass
DAYCLONA
Mass
I'm sure most racer's love there Holley carbs. I personally hate them. I've never had one that you weren't constantly tweeking. Change in temp, air presure, a fly landing on the windsheild. Anything seems to change there tune. I don't want to spend 20 minuites every time i want to take the car out to tweak the carb.
I don't know Doug,....Holleys are perhaps the easiest carbs to tune, and stay tuned, while I personaly put a SIX PAK on everything,.....I've had my share of Carters, AFB, AVS, WCFB, Thermoquads, Eldebricks, Qjets, Predators, etc, over the decades,....Holleys IMHO are superior,.....but any fuel system, if "treated" wrong, can be a problem, tune/reliability wise......
[Re: DAYCLONA]
#359968
06/27/09 11:18 PM
06/27/09 11:18 PM
GreenBlurr
super gas
super gas
Renton, WA
Yeah, if you are having to tinker with your holley everytime you drive the car due to the car's not not running quite right or running different all of the time, then you have manifold vacuum leaks, and/or timing issues. Every holley I have ever built for myself or anyone else has done well in all seasons, once it is jetted into an acceptable zone that is not too rich when its warm and dry out, and does not run too lean when its cold and wet out. Adequate timing is also the partner of the carb when you get it where you need it.
Just take a step back and don't imagine holleys or the science behind them as so complicated. It's actually very simple and has a reliable method to it.
[Re: 440newport]
#359971
06/28/09 02:17 PM
06/28/09 02:17 PM
Posts: 1,163 NORTHERN VA
THESHAKERPROJECT
NORTHERN VA
Crower 271HDP
222/234 @ .050, 271/284, .486/.496
BINGO !!! Thats a GREAT CAM for a street/ strip car and check out the 112 LSA !! I have the one step hotter Crower 275 HDP in my 4000+LB 71 Charger R/T and I use a STOCK (1800 STALL)converter and 3.55 rear for 12.9 @109 mph with a 73 Thermoquad ! I used the 271 HDP in my SIXPACK Challenger R/T and that car should run min 12s. You can get the cam from Summit. ![](/ubbthreads/images/graemlins/beer.gif)
