Page 1 of 3 1 2 3
cam suggestions for 440 #359953
06/27/09 08:02 PM
06/27/09 08:02 PM
dark side of the moon
Dougsmopars Offline OP
I bought this 68 GTX with 440 automatic. It has a 750 double pumper which i'm going to replace with an Edelbrock 800 Thunder series. It has a racer brown cam in it of unknown specs. Very lumpy idle. Very poor vacuum. Way too much cam. Motor was rebuilt about 5000 miles ago according to previous owner. Has Torker intake Mopar ignition with orange box and headers. I'm looking for a good cam that will be very torque on bottom end. Something will make plenty of power from around 1500 to 5500 RPM. Would like to be able to put the power breaks back in the car. I made this mistake before installing to big a cam for a basically stock motor. I put a mopar 509 purple shaft in my Road Runner with 440 six pack 4 speed. It made less power then with stock cam. Any of you guy's have any suggestions? I was looking at some of the Lunati VOODO cams? Any thoughts? I want to keep it hydraulic.
Re: cam suggestions for 440 [Re: Dougsmopars] #359954
06/27/09 08:05 PM
06/27/09 08:05 PM
IA
landon1 Offline
landon1  Offline
IA
i looked at the voodoo cams, but i don't think too many people are running them in 440s - don't hear too much about them anyhow. i went with Comp XE 268. power in the same range you're looking for (basic street range). mine is not installed (still waiting on my block at the machine shop).
'71 Satellite Sebring 440
Re: cam suggestions for 440 [Re: Dougsmopars] #359955
06/27/09 08:08 PM
06/27/09 08:08 PM
Fresno, CA
cudamank Offline
cudamank  Offline
Fresno, CA
I run the Voodoo 60303, 440, .030 over, 10.5, 3400 stall, performer intake, 750 speed demon nice idle, still plenty of vacuum for my brakes.
Re: cam suggestions for 440 [Re: cudamank] #359956
06/27/09 08:42 PM
06/27/09 08:42 PM
is this the one your useing? Thyis is the one i was looking at. LUN-60303LK
Cam Style Hydraulic flat tappet
Basic Operating RPM Range 1,800-6,200
Intake Duration at 050 inch Lift 226
Exhaust Duration at 050 inch Lift 234
Duration at 050 inch Lift 226 int./234 exh.
Advertised Intake Duration 268
Advertised Exhaust Duration 276
Advertised Duration 268 int./276 exh.
Intake Valve Lift with Factory Rocker Arm Ratio 0.494 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio 0.513 in.
Valve Lift with Factory Rocker Arm Ratio 0.494 int./0.513 exh. lift
Lobe Separation (degrees) 110
Camshaft Gear Attachment 3-bolt
Re: cam suggestions for 440 [Re: Dougsmopars] #359957
06/27/09 08:52 PM
06/27/09 08:52 PM
i would say the cam in the motor now is over 300 duration with a lot of overlap. It is extremely lumpy at idle and doesn't even out till around 2000- 2300 RPM. Way to much cam for the motor.
Re: cam suggestions for 440 [Re: Dougsmopars] #359958
06/27/09 09:02 PM
06/27/09 09:02 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I bought the lunati voodoo 60303 cam for mine but haven't installed it yet. Should be a decent cam, just a small step more milder than the comp xe275hl which a lot of people have run.
Re: cam suggestions for 440 [Re: Dougsmopars] #359959
06/27/09 09:29 PM
06/27/09 09:29 PM
Renton, WA
GreenBlurr Offline
super gas
GreenBlurr  Offline
super gas
Renton, WA
You could start by NOT undercarbing your 440 like too many people on here seem to do. A holley 750 is nowhere near enough for that motor with that kind of cam....especially if it still has the same jetting it came with out of the box. And an edelbrock 800 will not be a step in the right direction either. Sure, they have good just off idle response in their accelerator shot, but they are lean as heck form there out becuase they do not hold any danged fuel.
You need a holley 850 double pumper for that motor that is properly jetted and fitted with squirters and eccelerator pump cams to compliment said jetting.
You will not recognize the motor in the world of difference in its runability and performance.
Re: cam suggestions for 440 [Re: GreenBlurr] #359960
06/27/09 09:36 PM
06/27/09 09:36 PM
Warren, MI
71TA Offline
71TA  Offline
Warren, MI
I went with the Mopar MP528 solid in my 470. GREAT CAM. Idles well. TONS of torque.
As far as "correct carbs". What I've learned is it's a TOTAL guesssing game without an LM1 air fuel meter. With one of those you can make a Dominator or a carm off a lawn mower work well.
www.DetroitMuscleTechnologies.com Mopar body and heater box restoration gaskets
Re: cam suggestions for 440 [Re: Dougsmopars] #359961
06/27/09 09:38 PM
06/27/09 09:38 PM
Fresno, CA
cudamank Offline
cudamank  Offline
Fresno, CA
That is the one. I really like it. I'll have to take audio of it and post it.
Remember remember the 11th of September, of murder and a terriosts plot. I see no reason why this treachery should ever be forgot.
Re: cam suggestions for 440 [Re: Dougsmopars] #359962
06/27/09 09:52 PM
06/27/09 09:52 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Looking for something to make low end torque, good idle, drivability,.....wanting to stay Hyd,
I'd pick something in the .470-.480 lift range with a total duration of no more than 260-270 based on your exsisting carb/intake and headers
might want to lose that Torker intake for a more "streetable" factory style DP
Cam manufacturer is your choice........
Re: cam suggestions for 440 [Re: DAYCLONA] #359963
06/27/09 10:00 PM
06/27/09 10:00 PM
Niles , Ohio
therocks Online content
therocks  Online Content
Niles , Ohio
For a decent cam for a driver I had luck with Summits big cam kit.Racy type idle pulls strong good vacuum and all around good for a streeter.One is still running in a 383 after 20 years.Id run a Holley Street Dominator with an 850 Holley.Rocky
Chrysler Firepower
Re: cam suggestions for 440 [Re: DAYCLONA] #359964
06/27/09 10:06 PM
06/27/09 10:06 PM
Don't get me wrong on the idle. I love a lumpy cam but the one in the motor now is just way too much. At 15 to 1800 RPM it's still rumpty rump. Car idle's like a pro stock. I'm guessing the cam is around 525 lift and over 300 duration. I'm not looking for a smooth idle like grand pa's car. I want a good tire frier that i can still have the power brake's.
Re: cam suggestions for 440 [Re: GreenBlurr] #359965
06/27/09 10:12 PM
06/27/09 10:12 PM
I'm sure most racer's love there Holley carbs. I personally hate them. I've never had one that you weren't constantly tweeking. Change in temp, air presure, a fly landing on the windsheild. Anything seems to change there tune. I'm not building a racer. I'm a Saturday night red light to red light guy. I like a good tire frier. I don't want to spend 20 minuites every time i want to take the car out to tweak the carb.
Re: cam suggestions for 440 [Re: Dougsmopars] #359966
06/27/09 10:16 PM
06/27/09 10:16 PM
IA
landon1 Offline
landon1  Offline
IA
i've had 2 holleys...a vacuum secondary and a mechanical (double pumper)....VS is not my favorite, didn't like it at all...but the DP was basically a "bolt on" part with no tweaking other than adjusting the idle speed. considered edelbrock, but have no experience with them, so i just stuck to what i know a little bit about
Re: cam suggestions for 440 [Re: Dougsmopars] #359967
06/27/09 11:08 PM
06/27/09 11:08 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I'm sure most racer's love there Holley carbs. I personally hate them. I've never had one that you weren't constantly tweeking. Change in temp, air presure, a fly landing on the windsheild. Anything seems to change there tune. I don't want to spend 20 minuites every time i want to take the car out to tweak the carb.
I don't know Doug,....Holleys are perhaps the easiest carbs to tune, and stay tuned, while I personaly put a SIX PAK on everything,.....I've had my share of Carters, AFB, AVS, WCFB, Thermoquads, Eldebricks, Qjets, Predators, etc, over the decades,....Holleys IMHO are superior,.....but any fuel system, if "treated" wrong, can be a problem, tune/reliability wise......
Re: cam suggestions for 440 [Re: DAYCLONA] #359968
06/27/09 11:18 PM
06/27/09 11:18 PM
Renton, WA
GreenBlurr Offline
super gas
GreenBlurr  Offline
super gas
Renton, WA
Yeah, if you are having to tinker with your holley everytime you drive the car due to the car's not not running quite right or running different all of the time, then you have manifold vacuum leaks, and/or timing issues.
Every holley I have ever built for myself or anyone else has done well in all seasons, once it is jetted into an acceptable zone that is not too rich when its warm and dry out, and does not run too lean when its cold and wet out. Adequate timing is also the partner of the carb when you get it where you need it.
Just take a step back and don't imagine holleys or the science behind them as so complicated. It's actually very simple and has a reliable method to it.
Re: cam suggestions for 440 [Re: GreenBlurr] #359969
06/28/09 12:55 AM
06/28/09 12:55 AM
St. John's Newfoundland
440newport Online content
440newport  Online Content
Crower 271HDP
222/234 @ .050, 271/284, .486/.496
Re: cam suggestions for 440 [Re: Dougsmopars] #359970
06/28/09 01:39 PM
06/28/09 01:39 PM
michigan
black64 Offline
black64  Offline
michigan
lunati 603 cam
Re: cam suggestions for 440 [Re: 440newport] #359971
06/28/09 02:17 PM
06/28/09 02:17 PM
NORTHERN VA
THESHAKERPROJECT Offline
NORTHERN VA
Crower 271HDP
BINGO !!! Thats a GREAT CAM for a street/ strip car and check out the 112 LSA !! I have the one step hotter Crower 275 HDP in my 4000+LB 71 Charger R/T and I use a STOCK (1800 STALL)converter and 3.55 rear for 12.9 @109 mph with a 73 Thermoquad ! I used the 271 HDP in my SIXPACK Challenger R/T and that car should run min 12s.
You can get the cam from Summit.
Re: cam suggestions for 440 [Re: GreenBlurr] #359972
06/29/09 09:24 AM
06/29/09 09:24 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
well a 750DP is a fine carb for a mild 440. What killed his 509 is probably lack of gear and stall. The thundr 800 is not as good as the 750DP. Or compression or all of the above. That said if you are going to buy a new carb the 850 would be better. As far as cam what gears are you running and what stall? That VooDoo is going to like at least a 2800 stall and some 3.91's to work well.
Coming soon!!!!
Page 1 of 3 1 2 3
