noisy motor #359922
06/27/09 07:38 PM
06/27/09 07:38 PM
USA
74DS Offline OP
74DS  Offline OP
USA
Help ! I have a rattling type sound at idle only .. it sounds like it is coming from the bottom end .. Any suggestions ?
Re: noisy motor [Re: 74DS] #359923
06/27/09 07:53 PM
06/27/09 07:53 PM
the boonies
aarcuda Offline
aarcuda  Offline
the boonies
Torque converter shield hitting the bolts
Re: noisy motor [Re: 74DS] #359924
06/27/09 07:58 PM
06/27/09 07:58 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
New motor rebuild ???, please tell us about it so that we can have something to go on.
Re: noisy motor [Re: MoparforLife] #359925
06/27/09 08:15 PM
06/27/09 08:15 PM
USA
74DS Offline OP
74DS  Offline OP
USA
fairly new ... 100 miles on it .. it is a 416 ( 340 stroker ) .. doesn't sound like a rod though ... ? only notice it at idle .. does sound like something is hitting something else .. it does have a windage tray ( Milodon ) and a gear drive ..
Re: noisy motor [Re: 74DS] #359926
06/27/09 10:07 PM
06/27/09 10:07 PM
scratchnfotraction Offline
sound like valve clatter or metal hitting metal?
all that bling and a 2$ chain to hold it down
you need a better torque strap than that
that chain is like lipstick on a pig
nice looking engine though,
verter bolts coming loose maybe?
Re: noisy motor [Re: scratchnfotraction] #359927
06/27/09 10:12 PM
06/27/09 10:12 PM
USA
74DS Offline OP
74DS  Offline OP
USA
sounds kinda like metal scraping or rubbing ... Any suggestions for a torque strap ?
Re: noisy motor [Re: scratchnfotraction] #359928
06/27/09 10:14 PM
06/27/09 10:14 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
The chain will work just as good as anything else. I'm not all that impressed with the name brand rig that I got for mine.
I want my fair share
Re: noisy motor [Re: SomeCarGuy] #359929
06/27/09 10:20 PM
06/27/09 10:20 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
At least it's a pretty chain. I've used them. Does the noise change from cold to hot?
Re: noisy motor [Re: buildanother] #359930
06/27/09 10:50 PM
06/27/09 10:50 PM
USA
74DS Offline OP
74DS  Offline OP
USA
no change from hot to cold .. does it only at idle (900rpm) any increase in rpm the noise seems to go away ..
thanks dave
Re: noisy motor [Re: 74DS] #359931
06/28/09 01:02 AM
06/28/09 01:02 AM
SomeCarGuy Offline
SomeCarGuy  Offline
Maybe some of those pulleys are ever so slightly hitting bolt(s). I had some aftermarket pulleys do that, took a grinder to the face of the offending bolts.
As was said, the TC bolts might be hitting, as might a bad stone sheild down there. I had one that was cracked but not aparent until it was removed. As in removed to replace the engine with a junkyard motor I got because I had given up trying to find the noise...
Re: noisy motor [Re: SomeCarGuy] #359932
06/28/09 07:20 AM
06/28/09 07:20 AM
Upper Midwest
Upper Midwest
Did you chaeck the rod clearance between the rod bolts and the windage tray???
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: noisy motor [Re: MoparforLife] #359933
06/28/09 12:33 PM
06/28/09 12:33 PM
USA
74DS Offline OP
74DS  Offline OP
USA
First off ... THANKS for the replies !! I started checking flex plate to converter bolts .. they seemed ok .. then the bad news .. the flex plate to crankshaft bolts are LOOSE ! I am sure I used locktite on them ?? Next Question ,, will it be easier to remove bolts and slide trans back enough to get to the flex to crank bolts ..or pull motor to get to them ?
Thanks in advance !!
Re: noisy motor [Re: 74DS] #359934
06/28/09 12:53 PM
06/28/09 12:53 PM
calif
cupcake Offline
cupcake  Offline
calif
i had problems with rod bolt hitting windage
Re: noisy motor [Re: 74DS] #359935
06/28/09 01:23 PM
06/28/09 01:23 PM
chicagoland,usa
chicagoland,usa
If you can, pull the trans out so you can see if the flexplate is toast or not.
Re: noisy motor [Re: 74DS] #359936
06/28/09 02:37 PM
06/28/09 02:37 PM
MNobody Offline
MNobody  Offline
I had that happen on my 440 once, i think i removed the torque converter bolts, unbolted the tranny and slid it back. make sure the holes in the flex plate are'nt egg shaped.
Re: noisy motor [Re: buildanother] #359937
06/28/09 02:38 PM
06/28/09 02:38 PM
hey!,thats what I suggested
drop the tranny
change the bolts and the flex plate,it used now,and most likly worn,IMO
I would put another seal in just cause it was down,the converter moveing around might hurt the seal...might not...dont want to pull it a 2nd time thats for sure
how are the rest of external seals on the tranny?
now would be the time to service it,IMO
good luck
