what size thread is a holley squirter screw?? #35950
04/15/07 10:26 PM
04/15/07 10:26 PM
elmira ny
hp340nos Offline OP
hp340nos  Offline OP
elmira ny
i stripped the main body and need to helicoil it where the squirter bolt threads in.what size is the bolt?
Re: what size thread is a holley squirter screw?? [Re: hp340nos] #35951
04/15/07 10:37 PM
04/15/07 10:37 PM
Columbus, Ohio
wheelsup68dart Offline
Columbus, Ohio
Uh.... 10-32 mabey
Re: what size thread is a holley squirter screw?? [Re: wheelsup68dart] #35952
04/15/07 11:11 PM
04/15/07 11:11 PM
elmira ny
hp340nos Offline OP
hp340nos  Offline OP
elmira ny
i tried a 10-32 tap up against the hollow squirter screw threads and it doesnt match up.any other ideas for thread size??
Re: what size thread is a holley squirter screw?? [Re: hp340nos] #35953
04/16/07 08:01 AM
04/16/07 08:01 AM
Owego, NY
JBurch Offline
JBurch  Offline
Owego, NY
Get a set of thread gauge's. Then you can go on the search for a heilcoil, OR you might try one of the epoxy thread repair kits.
Good luck!!
Re: what size thread is a holley squirter screw?? [Re: JBurch] #35954
04/16/07 08:08 AM
04/16/07 08:08 AM
Northeast, Alpine, NY
9
9 Sec Phill Offline
On a road near you
9 Sec Phill  Offline
On a road near you
9
Mike, Buy a set of screws with the holes through the center of them, they usualy have a thick head, take them to a machine shop and have them take some material off the bottom of the head and them the screw will reach the threads still left in the hole. .....Phill
Re: what size thread is a holley squirter screw?? [Re: 9 Sec Phill] #35955
04/16/07 08:52 AM
04/16/07 08:52 AM
Hampton Va
gtsdon Offline
gtsdon  Offline
Hampton Va
In my opinion you would be better off buying a Pro Form or Holly center section to replace the one you have. By the time you get done chasing parts or labor with today’s gas prices you might even be saving money. Just my
Re: what size thread is a holley squirter screw?? [Re: gtsdon] #35956
04/16/07 11:22 AM
04/16/07 11:22 AM
Mo.
supercomp Offline
supercomp  Offline
Mo.
It's a #12 x 28 thread. A real oddball. If you helicoil it you'll have to use a hollow screw because you'll be getting rid of your slots where the gas comes up around the solid screw.
Re: what size thread is a holley squirter screw?? [Re: supercomp] #35957
04/16/07 11:40 AM
04/16/07 11:40 AM
elmira ny
hp340nos Offline OP
hp340nos  Offline OP
elmira ny
jim; i agree with u,i have thread gages at work will double check thread size;
phil;i used the hollow screws thats what caused the problem,there was a burr on the bottom where the slot is cut,it threaded in fine but when i removed it,threads were pulled.
gts don ; yes if i have to i will buy a new body,this carb i have now has alot of work just trying to fix it if i can.
comp;thanks thats what i was thinking was 12-28 thread.
thanks for the help guys i will now try to find a heli-coil kit in 12-28 .thanks mike
Re: what size thread is a holley squirter screw?? [Re: hp340nos] #35958
04/16/07 11:51 AM
04/16/07 11:51 AM
Mo.
supercomp Offline
supercomp  Offline
Mo.
What I've done for friends a couple of times is shorten the check needle that's under the screw up so it gave me a few threads for the screw to bite and it worked okay. A lot of Ford holleys on 460 trucks have a check needle that's only about half the length of the standard needle and they work fine. They are also aluminum so loosing the weight won't keep it from seating . Just a thought.
Re: what size thread is a holley squirter screw?? [Re: hp340nos] #35959
04/16/07 01:15 PM
04/16/07 01:15 PM
Bloomingdale , OH
super451b Online content
super451b  Online Content
Bloomingdale , OH
This place sells a repair kit for that. Look in their online catalog under carb parts and fuel lines. It listed as : pump nozzle screw repair kit.
http://www.blp.com/frmCatalog.htm
Re: what size thread is a holley squirter screw?? [Re: super451b] #35960
04/16/07 02:12 PM
04/16/07 02:12 PM
elmira ny
hp340nos Offline OP
hp340nos  Offline OP
elmira ny
that is a nice kit,simple too,i just oredered a heli-coil kit the thread is 12-28 for a squirter and the fuel bowl is a 12-24 thread.what is the purpose of the needle under the squirter?should it be loose when squirter is tightened in ?as in it would rattle if carb is shaken?thanks again guys
Re: what size thread is a holley squirter screw?? [Re: gtsdon] #35961
04/16/07 02:18 PM
04/16/07 02:18 PM
Q
Quicktree Offline
Quicktree  Offline
Q
been there done that.
Re: what size thread is a holley squirter screw?? [Re: hp340nos] #35962
04/17/07 10:20 AM
04/17/07 10:20 AM
Mo.
supercomp Offline
supercomp  Offline
Mo.
It has to have room to raise up a small amount to let gas up past the needle. It's purpose is to seat when you let off the throttle to make the accelerator pump cavity pull gas from the bowl to refill the cavity with gas instead of pulling air back through the squirter into the pump cavity, which it will do. I've seen guy's scratching their heads when they left it out.
