hi, been driving my 493ci Imperial around in the hot weather, then watching the light flicker and the oil pressure dropping to ~15# at idle after a long freeway run. the car has the original (5qt?) c-body pan, HP pump, 20w50 oil. i was thinking a cooler would help with the temp of course and add some capacity to the sump.
i've been looking at the Canton spin on adapters, has anoybody done this on a bb and is it better to just relocate the filter too, maybe add a 2nd filter, then what size cooler would you recommend, then would you consider a hi-volume pump, etc etc.
thanks for your help
