Page 3 of 4 1 2 3 4
Re: Help with Lokar Kickdown Cable [Re: Junky] #357497
07/14/09 08:55 AM
07/14/09 08:55 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
For anyone that cares:
I installed mine with minimal effort. The throttle pressure lever is all but all the way back at WOT. At very light throttle (granny driving) it shifts into 3rd arould 15 mph. Leaving it in Drive with the throttle to the floor it will shift gear to gear right about 4,900 RPM's. Disclosure: I do run the TransGo "shift kit". I've been running it this way for over 5 years now. The transmission shifts as solid today as it did 5 years ago. I'm convinced that it is working as good, if not better, than the stock setup...and looks better too.
Junky WOT throttle shifts are controlled by the govenor weights in the back of the trans .
Stumpy/Richard/Dick ... lighten up Francis , are you installing the Lokar out of the box or are you fixing it so it operates CORRECTLY ??? I'll go on a limb and say that most of the buyers of the Lokar install it out of the box and call it good when it's not.
Re: Help with Lokar Kickdown Cable [Re: JohnRR] #357498
07/14/09 10:19 AM
07/14/09 10:19 AM
scratchnfotraction Offline
dummy 101 here
LBAMVB is the the correct way to loose the tpcl
or swap in a 4 speed
Re: Help with Lokar Kickdown Cable [Re: scratchnfotraction] #357499
07/14/09 10:33 AM
07/14/09 10:33 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
dummy 101 here
Re: Help with Lokar Kickdown Cable [Re: Challenger 1] #357500
07/14/09 10:54 AM
07/14/09 10:54 AM
the house on the left.
cogen80 Offline
cogen80  Offline
Not a problem? OK, if you say so. It's not unusual to see these Lokar installations have light throttle 1-2 shifts at 25+ mph and 2-3 at 40+ mph or even higher and, possibly, no 2-3 upshift at all. If that's OK with you then, "no problem". If the cable is adjusted for correct light throttle shift points there is insufficient TP at WOT and no forced downshifts. Potential damage.
man i don't know what you are doing or whoever is installing lokar set ups that are having those problems are doing but i have been using lokar kick downs since the early to mid 90's, installed them on all my cars and numerous friends car and have never run into a problem like you describe. sounds like total idiots installed the ones your talking about. some people just should not wrench on their cars. the kick down sure isn't rocker science.
Throttle pressure, not a kick down!!! Right John?
I bet alot of manuel valve bodies have been sold over the years because of the confusion over TP on TF.
call it what you want. its a kickdown cable or kickdown linkage to most people.
Re: Help with Lokar Kickdown Cable [Re: JohnRR] #357501
07/14/09 10:57 AM
07/14/09 10:57 AM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
Junky WOT throttle shifts are controlled by the govenor weights in the back of the trans , but you give a perfect example of what J. Kunkel is talking about, people think it's working fine when it's really not, it won't fry the trans overnight.
Can you please point out where my setup is not working fine? So I get the explanation of WOT shifts incorrect and now I'm incompetent? And the Lokar kit isn't working correctly? There is nothing about my setup that suggests that it's not working properly. This is not based on what I THINK, it's based on my experience of the situation. Have you worked on or driven my Coronet? Perfect example, my foot. Enough said.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: Help with Lokar Kickdown Cable [Re: cogen80] #357502
07/14/09 11:12 AM
07/14/09 11:12 AM
Cincinnati, Ohio
Cincinnati, Ohio
I was just kidding you...
Re: Help with Lokar Kickdown Cable [Re: Junky] #357503
07/14/09 11:13 AM
07/14/09 11:13 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
My bad and I will edit, I confused your post with another poster that SAID HE FRYED his trans with a LOAKR he THOUGHT was working properly .
I was trying to consolidate replies , silly me ...
Re: Help with Lokar Kickdown Cable [Re: 73swinger] #357504
07/14/09 11:15 AM
07/14/09 11:15 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
So, as I've repeatedly ranted, the Lokar works OK if the installer knows to match the total travel of the cable attach points and installs a spring.
The Bouchillon kit contains the trans lever so there's no mismatch in travel and it uses a more robust, easily located cable.
I think this is the main thing Lokar buyers should be aware of. My first observation of the Lokar kit was the horrible directions. I installed mine as per directions on a freshly rebuilt 727 & thought it was right, 2 years & the tranny was toast. Then I learned more about throttle position importance, had the trans. rebuilt again, and again used the Lokar cable, WITH MODIFIED MOUNT POSITION ON TRANS. KICK DOWN LEVER. Its working fine so far, but I keep a close eye on adjustment. I bought it, I'm using it, but I would not buy another one. Bouchillion or a manual valve body next time.
You give a perfect example of what J. Kunkel is talking about, people think it's working fine when it's really not, it won't fry the trans overnight.
Re: Help with Lokar Kickdown Cable [Re: JohnRR] #357505
07/14/09 11:22 AM
07/14/09 11:22 AM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
Thank you, sir, for the correction to your comments and for informing me of the workings of the WOT shift points.
Re: Help with Lokar Kickdown Cable [Re: Challenger 1] #357506
07/14/09 11:49 AM
07/14/09 11:49 AM
SoCal
68HemiB Offline
68HemiB  Offline
SoCal
dummy 101 here
Let's Buy A Manual Valve Body is the correct way to lose the throttle pressure control linkage.
Or something close.
Down to just a blue car now.
Re: Help with Lokar Kickdown Cable [Re: 68HemiB] #357507
07/14/09 12:02 PM
07/14/09 12:02 PM
Cincinnati, Ohio
Cincinnati, Ohio
dummy 101 here
Or something close.
Ahhh, thank you.
Re: Help with Lokar Kickdown Cable [Re: 68HemiB] #357508
07/14/09 01:57 PM
07/14/09 01:57 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
dummy 101 here
Or something close.
Low Band Apply Manual Valve Body
Re: Help with Lokar Kickdown Cable [Re: KAHUDA] #357509
07/14/09 02:06 PM
07/14/09 02:06 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
OK all you Lokar guys, I just received mine and I'm in the middle of installing it. I could really use some advice, tips, step-by-step detailed instructions on how to get it adjusted so it works properly. In case it matters, it's on a '70 Cuda, 440-6, 727.
THANKS!!
IT WILL NOT WORK ON A 6-Pack... return it and get a Man valve body or eat $350 and get the correct KICK-DOWN or whatever you want to call it.
Coming soon!!!!
Re: Help with Lokar Kickdown Cable [Re: Mr.Yuck] #357510
07/14/09 02:10 PM
07/14/09 02:10 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
See this piece??? your 6-pack 'aint got one. SOOOO you will have to fabricate one. I looked around an nobody seems to have one or know what I'm talking about. I had a Lokar, I fumbled with it and it's terrrrrrrrrrrrriiiiiiible instructions for 20 minutes before I but it back in the box.
Coming soon!!!!
Re: Help with Lokar Kickdown Cable [Re: JohnRR] #357511
07/14/09 02:59 PM
07/14/09 02:59 PM
yes,Johnahah is correct
low band apply manual valve body
lets buy a manual valve body was a good try though
IMO the bouchillon looks like its all from a 93 Dak...my 93 Dak has every thing but the lever that goes on the carb for the right ratio
rplacement cable from the dealer fits it,and the lever on the tranz is the same as far as I can tell
seems they worked it out at ma mopar and bouchillon just went a little further adapting it to the carb
I have burnt up more trannys than I care to admit,and its all because I have not got the right throttle pressure control linkage and its close to right but not right...
so to loose it,get the LBAMVB or a 4 speed
Re: Help with Lokar Kickdown Cable [Re: Mr.Yuck] #357512
07/14/09 03:17 PM
07/14/09 03:17 PM
Cincinnati, Ohio
Cincinnati, Ohio
I guess you didn't look at my picture above.Didn't cost me anything, because I had it laying around.
Re: Help with Lokar Kickdown Cable [Re: stumpy] #357513
07/14/09 04:01 PM
07/14/09 04:01 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Anything you say John. The rest of us are just too stupid to know when we have something that doesn't work as we drive with it every day for years without any failures.
I made a statement containing the words many of those and you seem to assume that I, somehow, was directing the comment at you and your installation(s).
Since I gave clear examples of how the installation can go wrong, and you with your God-given prowess aren't having those problems, I would respectfully suggest you get off of your "I wanna argue about everything" mode and recognize that the comment wasn't aimed at everybody.."some" being the operative word.
Re: Help with Lokar Kickdown Cable [Re: Challenger 1] #357514
07/14/09 04:48 PM
07/14/09 04:48 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
No I didn't some pic's don't open at work..anyway what is that from? how long did it take to rig up? I just got a new man valve body form a buddy... it will be going in sooooon. Then I can drop kick all this junk.
Coming soon!!!!
Re: Help with Lokar Kickdown Cable [Re: Mr.Yuck] #357515
07/14/09 05:42 PM
07/14/09 05:42 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
"I would respectfully suggest you get off of your "I wanna argue about everything" mode". You might try taking your own advice.
Re: Help with Lokar Kickdown Cable [Re: stumpy] #357516
07/14/09 05:51 PM
07/14/09 05:51 PM
Page 3 of 4 1 2 3 4
