Page 1 of 4 1 2 3 4
Help with Lokar Kickdown Cable #357457
06/25/09 10:27 AM
06/25/09 10:27 AM
CHRGR69 Offline OP
CHRGR69  Offline OP
Just ordered a kit from Summit for my 71 Cuda 383 727 tranny. Has the cable and carb bracket. Anybody install one? Advice?
Grandma always said I had "hands of gold"!
Re: Help with Lokar Kickdown Cable [Re: CHRGR69] #357458
06/25/09 03:01 PM
06/25/09 03:01 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I run one my 360 with an A500 behind it. Works ok. Bracket is a little flimsy, and I had to add another spring down on the trans, but can't remember why. Also, the trans bracket hit my trans tunnel. I will be making a better fitting one later. For now, I just bent the stock one.
You will want to pull some tension on it, and then drive it to see where it shifts. More tension, higher shift point. Pretty simple.
Re: Help with Lokar Kickdown Cable [Re: CHRGR69] #357459
06/25/09 03:33 PM
06/25/09 03:33 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
I have one on my 66 Coronet w/440 and 4V it works great. Follow the instructions to the letter. I ordered the matching throttle cable because they work well together and use a common bracket. I'll try and get a pic for you today.
Re: Help with Lokar Kickdown Cable [Re: Lefty] #357460
06/25/09 03:43 PM
06/25/09 03:43 PM
The cable kit from Bouchillion Performance makes that Lokar look like the toy it is--PLEASE everyone look at the Bouchillion piece--it is a tranny saver and problem solver--good piece period!
Re: Help with Lokar Kickdown Cable [Re: Lefty] #357461
06/25/09 03:43 PM
06/25/09 03:43 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
A pic would be awesome! Thanks
Re: Help with Lokar Kickdown Cable [Re: ] #357462
06/25/09 04:39 PM
06/25/09 04:39 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The lokar kit bites from all the posts I have seen on this very site , the ratio the lever moves is not the same as the factory movement , one needs to trial and error by drilling holes to get it correct .
The bouchillon is plug and play , again from posts on it made on this site .
you've been WARNED ...
Re: Help with Lokar Kickdown Cable [Re: ] #357463
06/25/09 08:12 PM
06/25/09 08:12 PM
North Dakota
440abody Offline
440abody  Offline
North Dakota
AMEN TO THAT BROTHER! Take your hard earned money, and return the Lokar to Summit and call Bouchillion and get a qualtiy piece. I have had both, and I too followed the instructions for the lokar to the letter, and never got the thing to work right(believe me I tried to make it work). The Bouchillion works great and they are good folks to deal with.
73 Dart Swinger 440/727 8.75 w/3.55's
34 Ford 3w coupe with a soon to be 1958 392HEMI!
Re: Help with Lokar Kickdown Cable [Re: 440abody] #357464
06/25/09 09:17 PM
06/25/09 09:17 PM
Pittsburgh, Pa
Jeff_383 Offline
Jeff_383  Offline
Pittsburgh, Pa
I have to agree with the above. I had the Lokar for 6 years, tinkering constantly. Finally bit the bullet, admitted defeat, and spent the money on the Bouchillon. Took a little time to adjust just right, but way better. Wish I had bought it first.
Re: Help with Lokar Kickdown Cable [Re: Jeff_383] #357465
06/26/09 12:07 AM
06/26/09 12:07 AM
Pasco, WA
440mag Offline
440mag  Offline
Pasco, WA
My lokar cable and bracket worked great. It took about 3 or 4 adjustments and the car shifts better than ever.
Re: Help with Lokar Kickdown Cable [Re: 440mag] #357466
06/26/09 12:13 AM
06/26/09 12:13 AM
colorado
chargermop Offline
chargermop  Offline
colorado
To get the lokar to work you first have to take it and throw it as far as you can , then get on the phone and get a Bouchillion Performance cable set up... my
Re: Help with Lokar Kickdown Cable [Re: chargermop] #357467
06/26/09 10:53 AM
06/26/09 10:53 AM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
I don't have any problems with mine. Shifts just fine. A clean and easy install.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: Help with Lokar Kickdown Cable [Re: Junky] #357468
06/26/09 11:04 AM
06/26/09 11:04 AM
the house on the left.
cogen80 Offline
cogen80  Offline
i have run the lokar cable kit on many cars and have never had a problem with it. great piece if you ask me.
Re: Help with Lokar Kickdown Cable [Re: cogen80] #357469
06/26/09 11:46 AM
06/26/09 11:46 AM
Oh
RacerGofKGB Offline
Got The Big One
RacerGofKGB  Offline
Got The Big One
Oh
I have one hanging on the wall in my garage. I plan to put it on my car when i get it finished. Ill let you know how it goes in about 5 years.
Re: Help with Lokar Kickdown Cable [Re: RacerGofKGB] #357470
06/26/09 11:49 AM
06/26/09 11:49 AM
hi
sharpie Offline
Moparts Linguist
sharpie  Offline
Moparts Linguist
hi
I run a Lokar cable kickdown. I don't have it adjusted to where I want yet, but it's not hard to adjust for me just takes two people.
Re: Help with Lokar Kickdown Cable [Re: sharpie] #357471
06/26/09 12:12 PM
06/26/09 12:12 PM
Southington, Ohio
dm69charger Offline
dm69charger  Offline
Southington, Ohio
I have one on mine and do not have any problems with it. It works great!!!
Re: Help with Lokar Kickdown Cable [Re: dm69charger] #357472
06/26/09 12:28 PM
06/26/09 12:28 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
I'm using a lokar on my truck with no problems. Been on there three years and two different transmissions 727 & 518.
Re: Help with Lokar Kickdown Cable [Re: stumpy] #357473
06/26/09 12:46 PM
06/26/09 12:46 PM
North Chicagoland
N
newbee69 Offline
newbee69  Offline
N
North Chicagoland
Personally, I run the bouchillion cuz of easier install and I am lazy.
But, I dont see why everyone is bad mouthing the Lokar. I know a few people who have it and absolutely no problems.
There is some trial and error invloved in the adjustment so you will probly have to play with it a little bit. Big deal.
The only thing my buddy was barking about when installing his is that the bracket is a little flimsy. But once he got it right, never had a problem since. Good Luck.
Re: Help with Lokar Kickdown Cable [Re: stumpy] #357474
06/26/09 02:00 PM
06/26/09 02:00 PM
CHRGR69 Offline OP
CHRGR69  Offline OP
Seems like I should be OK from the responses. Besides, when dealing with a 38 year old car, you become used to dealing with issues. No biggie! Thanks guys.
Re: Help with Lokar Kickdown Cable [Re: CHRGR69] #357475
06/26/09 04:37 PM
06/26/09 04:37 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
It's worth noting that many of those who claim to have no problems with the Lokar actually do have problems, they just don't know it.
Re: Help with Lokar Kickdown Cable [Re: CHRGR69] #357476
06/26/09 07:19 PM
06/26/09 07:19 PM
Lefty Offline
Lefty  Offline
You're looking at three things - Throttle cable kit, kick down kit, bracket kit...
Here ya go -
Page 1 of 4 1 2 3 4
