A-Body Pitman Arm?????/
#357165
06/24/09 09:42 PM
06/24/09 09:42 PM
Posts: 341 New Jersey
U_Code_Cuda
New Jersey
I just tried to replaced my original pitman arm on my 1971 Demon340 and found that the new unit(raybestos #4451008) has a totally different bend and angle to it??????? Did they reconfigure the design from the original Mopar # 3402730 ??????? It seams to have the pivot arm inverted?? Thanks, Steven
1970 R/T Challenger 4-speed 1971 Demon 340 3-speed
Re: A-Body Pitman Arm?????/
[Re: RokketRide]
#357167
06/24/09 10:19 PM
06/24/09 10:19 PM
U_Code_Cuda
New Jersey
Will it work the same.....The car has power steering if that matters. Rock Auto lists this part # as the only 1 available.
[Re: RokketRide]
#357168
06/24/09 10:19 PM
06/24/09 10:19 PM
Posts: 70,126 Here
DirectSubjection
Tacohead. The First and Only
Here
Ride eternal, shiny and chrome
[Re: DirectSubjection]
#357170
06/24/09 10:47 PM
06/24/09 10:47 PM
U_Code_Cuda
New Jersey
Well this has become a problem.......The pic of a 73-76 pitman arm is what I took off but, the other photo is a idler arm right Anyway I think the power pump might be a later year 1973 so maybe the previous owner changed all of this???? The new pitman arm has a very deep bend and has the pivot facing 180. Do I use a 73 later pitman arm??? When i enter 73 Dart Sport my exact pitman arm comes up. Did he change the drag link to make it work??? I am so confused
#357173
06/24/09 10:58 PM
06/24/09 10:58 PM
U_Code_Cuda
New Jersey
Bingo, I have a 73 later setup but, how about the drag link, what is the difference between the 2??? So I can check the bends or #'s Also, the idler arm that came off resembles a early model arm??????? What The F@#$..... would that work properly 73-76 pitman and early idler arm
[Re: U_Code_Cuda]
#357175
06/24/09 11:04 PM
06/24/09 11:04 PM
Posts: 70,126 Here
DirectSubjection
Here
That pic i linked shows the later setup abovve, and the older one below. You can see how the 68-72 has more of a drop in the center. If you have the later 73+ pitman arm, you have the later link too.
[Re: U_Code_Cuda]
#357176
06/24/09 11:09 PM
06/24/09 11:09 PM
U_Code_Cuda
New Jersey
Also, the idler arm that came off resembles a early model arm??????? What The [Email]F@#$.....[/Email] would that work properly 73-76 pitman and early idler arm
Meaning the new idler arm I ordered looks the same as the one that came off.....
