Broken Exhaust Stud #356881
06/24/09 05:38 PM
06/24/09 05:38 PM
Babylon,NY
440_ci Offline OP
440_ci  Offline OP
Babylon,NY
Hey guys i have two exhaust studs broken off in the heads on my 440. I tried drilling for hours but its not really cutting it. Do any of you guys have any techniques or products you like to use when dealing with a really annoying stud? This is the last thing before the engine goes in and its holding everything up so ANY input is greatly appreciated. Thanks Guys
Re: Broken Exhaust Stud [Re: 440_ci] #356882
06/24/09 05:44 PM
06/24/09 05:44 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
Go to a tool-supply company and get a GOOD set of drill-bits. Your bits are probably dull. Go with a small drill bit first. And use cutting oils.
After the holes are drilled .. use the SQUARE extractors. The other ones are junk.
Re: Broken Exhaust Stud [Re: dOoC] #356883
06/24/09 05:46 PM
06/24/09 05:46 PM
Babylon,NY
440_ci Offline OP
440_ci  Offline OP
Babylon,NY
Okay will do , does anyone recommend any specific type of penetrating oils?
Re: Broken Exhaust Stud [Re: 440_ci] #356884
06/24/09 05:53 PM
06/24/09 05:53 PM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
Pen oil ? ... to loosen up the stud in the head? .. that will not work ....unless you want to work-that process for MONTHS !!
Re: Broken Exhaust Stud [Re: dOoC] #356885
06/24/09 05:57 PM
06/24/09 05:57 PM
Babylon,NY
440_ci Offline OP
440_ci  Offline OP
Babylon,NY
LoL o okay nvm that then, but as for the cutting oil what do you like?
Re: Broken Exhaust Stud [Re: 440_ci] #356886
06/24/09 06:03 PM
06/24/09 06:03 PM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
The cutting oil brand? ... it has been a while since I have used any and I am out of it me-self. I would just go to that GOOD and well-stocked tool-and-die tool supply store and tell them what you are doing. They should have that there in-stock.
Post what they say ...I need that info because I have 4 sets of heads(8 or so studs) I have to do !
Oh .... Sears has those GOOD square extractors.
Re: Broken Exhaust Stud [Re: dOoC] #356887
06/24/09 06:06 PM
06/24/09 06:06 PM
Babylon,NY
440_ci Offline OP
440_ci  Offline OP
Babylon,NY
8?!?!? i thought these two i had was alot so iell just tell em what i am doing and hopefully they have some good stuff. I will let you know what they tell me and hopefully those 8 you have arnt gonna be too much of a pain. Thanks
Re: Broken Exhaust Stud [Re: 440_ci] #356888
06/24/09 06:17 PM
06/24/09 06:17 PM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
Oh ... I have another 4 studs broken on a motorhome motor(but those have EZ access) !! ... and at least those other heads are not ON a motor.
Re: Broken Exhaust Stud [Re: 440_ci] #356889
06/24/09 06:19 PM
06/24/09 06:19 PM
michigan
black64 Offline
black64  Offline
michigan
How much of the stud is showing? Sometimes you can tack weld a smaller dia bolt to the stud and have something to grab onto to remove the stud. Heat to the stud also helps brake the crud loose on the threads. A few taps with a hammer after heating can help.
Re: Broken Exhaust Stud [Re: black64] #356890
06/24/09 06:41 PM
06/24/09 06:41 PM
SW FL
dodgedartgt Offline
dodgedartgt  Offline
SW FL
In the past, I have had some success with welding a nut to the broken stud. Clamp/hold an appropriate size nut in place and squirt it full of wire. Now it is a "bolt" and the heat has helped loosen it in the head.,.. sometimes.
Other times the nut has just twisted off and I'm back to drilling, extracting.
Good luck,
Mike Bynum
Re: Broken Exhaust Stud [Re: black64] #356891
06/24/09 06:43 PM
06/24/09 06:43 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
screw the extractors,,, drill the hole to size and retap. you think you have trouble now,, wait till you break an extractor..
I am truckless..
Re: Broken Exhaust Stud [Re: 340SHORTY] #356892
06/24/09 07:07 PM
06/24/09 07:07 PM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
A simple(but somewhat expensive) EDM procedure fixs THAT ...
Re: Broken Exhaust Stud [Re: 440_ci] #356893
06/24/09 07:41 PM
06/24/09 07:41 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
Last head I had with a broken stud cost $6 from the machine shop why play with it if you don't have to?
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: Broken Exhaust Stud [Re: Rug_Trucker] #356894
06/24/09 07:47 PM
06/24/09 07:47 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
guess that would depend on what you mean by "play"
some of us like to do these things. I don't, but some do. never had luck with extractors. Usualy drill and tap , and threadsert when needed.
$6.oo is a good price, don't think that will fly around, but I never checked.
Re: Broken Exhaust Stud [Re: Rug_Trucker] #356895
06/24/09 07:49 PM
06/24/09 07:49 PM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
An EDM for 6 bux ?
Re: Broken Exhaust Stud [Re: dOoC] #356896
06/24/09 09:35 PM
06/24/09 09:35 PM
Rug_Trucker Offline
Rug_Trucker  Offline
An EDM for 6 bux ?
Don't have a clue how they did it.
Re: Broken Exhaust Stud [Re: 340SHORTY] #356897
06/24/09 10:27 PM
06/24/09 10:27 PM
Queens,NY
Bogie Offline
Bogie  Offline
Queens,NY
Yep I did that a few weeks ago 2 different small block heads I broke 2 extractors. Never again I will drill and re tap anything I ever do.
66 Dart 170 Post 273HP/4 Spd 3.90's 84 w350 Crew Cab 360/4 Spd 4.10's 7" Lift 37" Super Swampers 91 Wrangler 4.0 For Sale - 2500 OBO Must GO 94 Grand Cherokee Laredo 4.0
Re: Broken Exhaust Stud [Re: Bogie] #356898
06/25/09 07:09 AM
06/25/09 07:09 AM
colorado
a12superbee Offline
a12superbee  Offline
colorado
Nobody mentioned it but use LEFT handed drill bits, as it bites it will help work the stud out.
I can't afford this. mark
Re: Broken Exhaust Stud [Re: a12superbee] #356899
06/25/09 07:14 AM
06/25/09 07:14 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I'd take the head to a shop and have somebody do it. It's one of those things that can go easy or go real bad. If the heads are off (and I wouldn't try if they were on the motor in the car) Just drop them off, have lunch and pick them up.
Coming soon!!!!
Re: Broken Exhaust Stud [Re: Mr.Yuck] #356900
06/25/09 12:34 PM
06/25/09 12:34 PM
SW Fla.
CYACOP Online content
CYACOP  Online Content
SW Fla.
Weld a nut on it
