Sloppy steering with new parts #356238
06/23/09 09:45 PM
06/23/09 09:45 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
I need to know if this is normal. All suspension parts are new. Steering box was rebuilt about two years ago to a "level II" by firm feel. It sat for two years while the car was being worked on. Now everything is connected and I can rotate about two inches the steering collum without any movement of the steering linkage. I'll grasp the rectangular piece that goes into the steering box and I can move it by hand about two inches. In the pics line up the roll pin with the red cap, this is where the linkage starts to turn the wheeles left. In the second pic I rotated, by hand, to the right and where the roll pin is in pic #2 is when the wheeles start to turn right. Is this normal or is there too much slop in here. The steering wheel flops all over the place. When the pump is hooked up will this slop go away??
Re: Sloppy steering with new parts [Re: frank] #356239
06/23/09 09:45 PM
06/23/09 09:45 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
Pic 2
Re: Sloppy steering with new parts [Re: frank] #356240
06/23/09 09:55 PM
06/23/09 09:55 PM
Brandon, Ms
cornet684me Offline
cornet684me  Offline
Brandon, Ms
i have a 1968 dodge coronet and i have the same play you have, i have been thru 2 steering boxes,
Re: Sloppy steering with new parts [Re: frank] #356241
06/23/09 09:56 PM
06/23/09 09:56 PM
Brandon, Ms
cornet684me Offline
cornet684me  Offline
Brandon, Ms
when running the play will be shorter however i still have a little play with the car running
Re: Sloppy steering with new parts [Re: frank] #356242
06/23/09 09:59 PM
06/23/09 09:59 PM
North Chicagoland
N
newbee69 Offline
newbee69  Offline
N
North Chicagoland
Thats about the same sloppiness as mine and Im just about to pop off the coupler and rebuild it. Just got the little kit yesterday.
But, then again, mine wasnt rebuilt 2 years ago.
Re: Sloppy steering with new parts [Re: frank] #356243
06/23/09 10:01 PM
06/23/09 10:01 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
It seems to me that (ps) mopars should be running to really evaluate excessive steering slop. I think they need fluid flowing through their circuits to properly diagnose.
Re: Sloppy steering with new parts [Re: newbee69] #356244
06/23/09 10:08 PM
06/23/09 10:08 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
Ya but it has zero miles. The steering colum was also rebuilt. Everything should be new.
Re: Sloppy steering with new parts [Re: buildanother] #356245
06/23/09 11:56 PM
06/23/09 11:56 PM
get that baby running!
Re: Sloppy steering with new parts [Re: frank] #356246
06/25/09 12:23 AM
06/25/09 12:23 AM
wisconsin
dodger1 Offline
dodger1  Offline
wisconsin
My Demon had alot of play because of the idler arm being sloppy and worn out, midas told me I needed a new steering box, when I went to have my tranny redone the mechanic told me my idler arm was shot.put a new one on and the slop was gone.
Re: Sloppy steering with new parts [Re: frank] #356247
06/25/09 01:04 AM
06/25/09 01:04 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Frank,.....My Firm Feel Stage 3 PS box has about the same play, when the car isn't running,....when it is running, the "feel" is very "firm"!,....no pun intended
Re: Sloppy steering with new parts [Re: dodger1] #356248
06/25/09 01:09 AM
06/25/09 01:09 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
The engine needs to be running..
Re: Sloppy steering with new parts [Re: 1_WILD_RT] #356249
06/25/09 08:32 PM
06/25/09 08:32 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
Thanks everyone
