Lokar throttle bracket and cruise control?
#35604
03/27/07 07:47 PM
03/27/07 07:47 PM
Posts: 3,136 Palm Coast, FL (near Daytona B...
Blown_Hemi
I have a Lokar throttle/kickdown cables and bracket mounted on my 440. Does anyone make a bracket so I can mount my factory cruise control cable to my engine? My Lokar bracket mounts to the carb so I would need a CC bracket, with factory clamp, that mounts to the manifold and be tall enough to connect to my 800DP, Performer RPM with a 1" spacer. Magnum HP, AndyF???????????????
Ask me my opinion of Frank Mitchell....... A Mopar crook!
Re: Lokar throttle bracket and cruise control?
[Re: Blown_Hemi]
#35608
07/29/09 01:02 PM
07/29/09 01:02 PM
Posts: 4,165 Florida
cataclysm80
Oops, looks like I forgot to do this. Better late than never huh?! I hope you got it all worked out. Maybe this pic can help someone else?
Bottom left is a used factory throttle cable clamp, which is the same part used as the cruise cable clamp on a cruise application.
Top left is a NOS big block throttle cable clamp / cruise cable bracket.
Top right is a NOS small block throttle cable clamp / cruise cable bracket.
Bottom right is a used factory nut for fastening either clamp to its respective bracket.
Tav
EDIT: Hmm, the pic didn't show up. Not sure why. Maybe the threads too old? If anyone needs the pic, just let me know and I'll post it for you elsewhere.
Tav
