Pistol Grip Question #355952
06/23/09 07:16 PM
06/23/09 07:16 PM
Arizona
anmracing Offline OP
Arizona
Ok, the bottom shifter in the picture.... Does anyone know what year B-body that is suppose to be in?
I need to know what year it's from so I can order one for a '69 B-body....
Re: Pistol Grip Question [Re: anmracing] #355953
06/23/09 07:17 PM
06/23/09 07:17 PM
1970 B body with a console.
Re: Pistol Grip Question [Re: ] #355954
06/23/09 07:54 PM
06/23/09 07:54 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
But will also fit any other 66-70 B-body cars with console. BTW, better knuckle clearance if you also use the 70 mechanism.
Re: Pistol Grip Question [Re: ScottSmith_Harms] #355955
06/24/09 09:40 AM
06/24/09 09:40 AM
Arizona
Arizona
Whats the diff between the machanisms? Is one angled more?
Thanks for the responses. Now to find the shifter........
EDIT: Wording was all wrong.......
Re: Pistol Grip Question [Re: anmracing] #355956
06/24/09 10:27 AM
06/24/09 10:27 AM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
Thanks for the responses, now to find one........
The difference is the length of the 3 fingers that stick out of the bottom of shifter mechanism. It will either lenghten the throw of the shifter or shorten the throw.
SHIFTER MECHANISMS
E-BODY #7180 ON REV Finger
70 B-BODY #7174 ON REV Finger
A/B-BODIES #6353 ON REV Finger
Re: Pistol Grip Question [Re: Cuda340] #355957
06/24/09 02:20 PM
06/24/09 02:20 PM
Arizona
Arizona
SHIFTER MECHANISMS
Cool! I'll check into that too....
Re: Pistol Grip Question [Re: anmracing] #355958
06/24/09 05:29 PM
06/24/09 05:29 PM
Central Ohio
Ledman_70 Offline
Ledman_70  Offline
Central Ohio
I had the bottom shifter handle in my 64 Polara with a console for a while, but then I installed the second handle, which is a 71 B body bench seat model. I had to make a little piece to step the handle over a little to clear the console, but it works great!
Jeff Adams 64 426 Polara
