A Body Steering Gearbox Question. #355815
06/23/09 03:42 PM
06/23/09 03:42 PM
MNobody Offline OP
MNobody  Offline OP
My 68 Dart Manual gear box has quite a bit of play in it, is there any adjustment on these?
Re: A Body Steering Gearbox Question. [Re: MNobody] #355816
06/23/09 07:53 PM
06/23/09 07:53 PM
Newfoundland Canada
Mopar1 Offline
Mopar1  Offline
Newfoundland Canada
Yes there is...There's a big nut on top of the box with a set screw in the centre of it. Loosen the nut, turn the set screw clockwise until the slop is gone, then hold the set screw while retighting the nut. Besure not to over-tighten the set screw.
Re: A Body Steering Gearbox Question. [Re: Mopar1] #355817
06/23/09 10:12 PM
06/23/09 10:12 PM
MNobody Offline OP
MNobody  Offline OP
Cool, Thanks
Re: A Body Steering Gearbox Question. [Re: Mopar1] #355818
06/23/09 11:23 PM
06/23/09 11:23 PM
Motown, Mi
P
PAULS_340 Offline
PAULS_340  Offline
P
Motown, Mi
Does a power steering box have the same adjustment screw?
Still looking for LM29H1B415501, '71 Demon 340
Re: A Body Steering Gearbox Question. [Re: PAULS_340] #355819
06/23/09 11:37 PM
06/23/09 11:37 PM
unfortunately no and on the manual box have the wheels straight ahead & wiggle the steering shaft lightly back & forth with one hand until the play is JUST gone with the other hand adjusting the set screw CW & as said lock it down & dont let the adj screw move
Re: A Body Steering Gearbox Question. [Re: RapidRobert] #355820
06/24/09 12:08 AM
06/24/09 12:08 AM
Newfoundland Canada
Mopar1 Offline
Mopar1  Offline
Newfoundland Canada
The power steering box on my '68 vert has the adjustment screw.
