B-body 8.75 in an A-body #355630
06/23/09 12:45 PM
06/23/09 12:45 PM
hi
sharpie Offline OP
Moparts Linguist
sharpie  Offline OP
Moparts Linguist
hi
I know the standard 66-70 rears will work in the rear of a fastback A-body, but what about an earlier? Is it correct that anywhere from 62 to 70 are correct?
Re: B-body 8.75 in an A-body [Re: sharpie] #355631
06/23/09 01:17 PM
06/23/09 01:17 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Here is a chart with the dimensions.
http://www.moparts.org/Tech/Archive/axle/17.html
Re: B-body 8.75 in an A-body [Re: Neil] #355632
06/23/09 01:23 PM
06/23/09 01:23 PM
North Riverside IL & Lowell IN
GTXKen Offline
super gas
GTXKen  Offline
super gas
If I'm reading that correctly the text and the chart contridict one another, for a 70 b-body vs a 66 anyway
Re: B-body 8.75 in an A-body [Re: Neil] #355633
06/23/09 02:01 PM
06/23/09 02:01 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
That chart is WRONG! That POS chart needs to go bye bye!
Use this one
http://www.moparts.org/Tech/Archive/axle/16.html
Re: B-body 8.75 in an A-body [Re: RobX4406] #355634
06/23/09 02:40 PM
06/23/09 02:40 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
65 to 67 would seem to be the best B body pic for an A body.
On an open wheel well car it's a straight bolt in.
Tire clearance is a little snug on a swept well(like a dart,) but still can be made to work with the right wheel.
Re: B-body 8.75 in an A-body [Re: dave571] #355635
06/23/09 02:41 PM
06/23/09 02:41 PM
hi
sharpie Offline OP
Moparts Linguist
sharpie  Offline OP
Moparts Linguist
hi
good thing I have a Demon then :-)
Re: B-body 8.75 in an A-body [Re: dave571] #355636
06/23/09 10:55 PM
06/23/09 10:55 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
65 to 67 would seem to be the best B body pic for an A body....
The 65 to 67 is the one to get. I think you can run the 5.72 Mustang backspace rims with those and maybe not even run a spacer. I believe the spring pads are a litlle further out, but I have heard of people just pushing them out a little to fit.
Problem is... 65 to 67 8 3/4 rears go for good money too. The 62-64 B-body guys want those to upgrage their cars from tapered axles.
But with a 65-67 you won't have the additional cost of LBP axles, backing plates, drums, lug studs... to do a A-body rear to LBP conversion.
Re: B-body 8.75 in an A-body [Re: sharpie] #355637
06/23/09 11:13 PM
06/23/09 11:13 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
Why not the A body rear end with Moser/Dutchman/Strange/whatever brand axles with the large bolt pattern??
Nautilus Racing-
Re: B-body 8.75 in an A-body [Re: Chris2581] #355638
06/23/09 11:20 PM
06/23/09 11:20 PM
Gilbert, AZ
Aspen7695 Offline
Aspen7695  Offline
Gilbert, AZ
I run a 66 B body rear end in my Duster. I moved the spring perches 1" on each side. I run 8" Welds with a 5 1/2" backspace. They fit just right. I now run 29.5X9X15 ET slicks which require a 7/16" spacer since the cross section is a bit over 11".
Raul
Re: B-body 8.75 in an A-body [Re: Chris2581] #355639
06/23/09 11:23 PM
06/23/09 11:23 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
$50-100 rear end vs $350 for bearings and axles along with buying a set of big bolt pattern brakes and a $300 housing.
Re: B-body 8.75 in an A-body [Re: sharpie] #355640
06/23/09 11:43 PM
06/23/09 11:43 PM
Tri-Cities, Washington
V
VITC_GTX Offline
VITC_GTX  Offline
V
Brian-
I put a B body rear ('69 Charger) in my '71 Demon. I didn't change a thing. Springs are just pushed out a touch to get them to sit on the perches. I have 27 X 10.5 slicks on 10" wheels with 5.5 backspacing. No problems...
Re: B-body 8.75 in an A-body [Re: VITC_GTX] #355641
06/25/09 07:16 AM
06/25/09 07:16 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
VITC, could you post a pic? I'd like to see how it looks....
2017 Grand Cherokee Overland
Re: B-body 8.75 in an A-body [Re: patrick] #355642
06/25/09 08:09 AM
06/25/09 08:09 AM
scratchnfotraction Offline
I would like to see a "GOOD" 50$-100$ 8 3/4 any thing
I had every thing from moser for 550$ and a 40$ chunk-3.55sg for an a-body
3 day turn around,fit perfect,been 9 yrs and just swaped out the green bearings
was in my 68 Dart and now in the 85 truck
do it right,do it once,it is an investment,IMO
Re: B-body 8.75 in an A-body [Re: VITC_GTX] #355643
06/25/09 09:57 AM
06/25/09 09:57 AM
SoCal
jake4cars Offline
jake4cars  Offline
SoCal
Brian-
Did the same thing 20 years in a 71 Valiant, I used rims from an AMC 4 wheel drive Eagle, I forget what tire size but they were big!
Joey
Re: B-body 8.75 in an A-body [Re: sharpie] #355644
06/25/09 07:29 PM
06/25/09 07:29 PM
San Jose,CA
migsBIG Offline
YouTube is my go-to news source
migsBIG  Offline
San Jose,CA
Should this mean I should keep an eye out at the show for one for your car?
Re: B-body 8.75 in an A-body [Re: migsBIG] #355645
06/25/09 07:31 PM
06/25/09 07:31 PM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
I agree 66-67 is diff ..than later 68-70 the chart is wrong!!! from my EXP
Re: B-body 8.75 in an A-body [Re: migsBIG] #355646
06/25/09 08:15 PM
06/25/09 08:15 PM
hi
sharpie Offline OP
Moparts Linguist
sharpie  Offline OP
Moparts Linguist
hi
Heh, if you would Miguel, I would be seriously grateful!
Re: B-body 8.75 in an A-body [Re: sharpie] #355647
06/25/09 08:31 PM
06/25/09 08:31 PM
San Jose,CA
migsBIG Offline
migsBIG  Offline
San Jose,CA
I plan on being there early, so I'll bring the measuring stick and see if I can poke one out from behind the bushes.
Re: B-body 8.75 in an A-body [Re: migsBIG] #355648
06/25/09 08:48 PM
06/25/09 08:48 PM
Taneytown, MD
bigslant6fan Offline
Taneytown, MD
I used a 68 b-body rear in a 71 duster.Spring perches need to be moved,then I used steel jeep wrangler rims.
Re: B-body 8.75 in an A-body [Re: bigslant6fan] #355649
07/03/09 03:30 PM
07/03/09 03:30 PM
Lake Orion, MI
goldduster318 Offline
Lake Orion, MI
here's some pictures of a '68 B-body axle in a '70 Duster. I used the MP offset shackle kit as well. 15x7 4.125 backspacing and 225 60R15's for now.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
