Dual four barral carburator calabration..HELP!
#355593
06/23/09 12:03 PM
06/23/09 12:03 PM
Posts: 2,506 Northern Pa
GLR
Northern Pa
I have a 452 (400-with 440 crank) stroker engine with mopar stage 6 heads-(stock) and a comp cam -270 duration with 470 lift with headers and it has two Edelbrock 650 CFM thunderseries carbs on it. I want to know waht I should use for primary and secondary jetting and also what metering rods and the step up springs should I use????? The carbs are stock calabration; Primary Jets-.095 Secondary Jets .098 Metering rods .068 x .047 with orange step up springs You can post here or send me an e-mail to; glr7069@ptd.net
