Dual four barral carburator calabration..HELP! #355593
06/23/09 12:03 PM
06/23/09 12:03 PM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
I have a 452 (400-with 440 crank) stroker engine with mopar stage 6 heads-(stock) and a comp cam -270 duration with 470 lift with headers and it has two Edelbrock 650 CFM thunderseries carbs on it.
I want to know waht I should use for primary and secondary jetting and also what metering rods and the step up springs should I use?????
The carbs are stock calabration;
Primary Jets-.095
Secondary Jets .098
Metering rods .068 x .047
with orange step up springs
You can post here or send me an e-mail to; glr7069@ptd.net
Re: Dual four barral carburator calabration..HELP! [Re: GLR] #355594
06/23/09 04:46 PM
06/23/09 04:46 PM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
Hemi guys? racers? anyone know?????
Re: Dual four barral carburator calabration..HELP! [Re: GLR] #355595
06/23/09 04:49 PM
06/23/09 04:49 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
You might do better asking in the Unlawful race only area. Those guys don't always get here.
Re: Dual four barral carburator calabration..HELP! [Re: stumpy] #355596
06/23/09 05:26 PM
06/23/09 05:26 PM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
Thanks!..
I put a post in there,
But I find it hard to beleave that no one has dual four barrels on there steet car.
Re: Dual four barral carburator calabration..HELP! [Re: GLR] #355597
06/23/09 07:53 PM
06/23/09 07:53 PM
chatham, Ilinois
fox Offline
super street
fox  Offline
super street
chatham, Ilinois
My advice it put it together and go drive it. It could be close.
Re: Dual four barral carburator calabration..HELP! [Re: fox] #355598
06/23/09 10:38 PM
06/23/09 10:38 PM
Northern Pa
GLR Offline OP
GLR  Offline OP
Northern Pa
Well, I would rather find out what the calabration should be and that way I won't damage anything
Re: Dual four barral carburator calabration..HELP! [Re: GLR] #355599
06/24/09 08:07 AM
06/24/09 08:07 AM
Greer, SC
TooMany62s Offline
TooMany62s  Offline
Greer, SC
For my 440 I went to one of the old mopar performance guides and used the jets suggested for the 2X4 super stock cars. I'm on the road so I don't have the numbers with me but if you PM me I'll look them up and send them to you when I get home this weekend.
Re: Dual four barral carburator calabration..HELP! [Re: GLR] #355600
06/24/09 08:17 AM
06/24/09 08:17 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I'd probably put them on as is and go from there. They will need adjusting no matter what you do. It also has a lot to do w/ the rest of your set-up, compression, stall gear, headers??? and so on.
Coming soon!!!!
Re: Dual four barral carburator calabration..HELP! [Re: GLR] #355601
06/24/09 08:25 AM
06/24/09 08:25 AM
Canada
CrAzYMoPaRGuY Offline
Canada
Thanks!..
I do, but mine isn't fired yet.
I have a 446ci with the same cam- 270H, but I have two Edelbrock 500s on a CH28...
I'm gonna get mine running and go from there, but my metering rod sizes won't matter to you cause my carbs are different....
CrAzYMoPaRGuY
Re: Dual four barral carburator calabration..HELP! [Re: GLR] #355602
06/24/09 08:27 AM
06/24/09 08:27 AM
If it's not pinging nor overheating no damage is being done just that your performance/mileage might not be optimum and you'd rather be slightly rich than too lean & I would inquire if those particular carbs are jetted stock on the rich side or the lean side. check your plugs until you can afford an innovate LM-2(with the rpm converter) to exactly find out(& get perfect) your air/fuel mixture
Re: Dual four barral carburator calabration..HELP! [Re: RapidRobert] #355603
06/24/09 08:40 AM
06/24/09 08:40 AM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Dan Dvorack sells a device for balancing two-four barrel set ups. I've never seen one in person.
