Re: Mopar Timing Tape
[Re: FY1TA & 65 Wedge]
#355414
06/23/09 08:34 AM
06/23/09 08:34 AM
RapidRobert
sb/bb both have a 7&1/4 dampener so yes the MP timing tape is the same. I would clean the surface well & iirc use some clear lacquer on top of the tape after it's on to keep it from flying off. You have a dampener that is not the std 7.25? I prefer to find actual TDC then mark the dampener with critical points such as 5,10,15,20,35,36 and 38.(1) degree is .0632683". ie 2&1/4"(2.246") is 35.5 degrees
[Re: Mr.Yuck]
#355416
06/23/09 09:22 AM
06/23/09 09:22 AM
do yourself a favor and go buy a nice timing light w/ an advance on it. the tape WILL fall off.
I disagree. In my lifetime I've seen a number of dialup timing lights on which the delay was incorrect. It may be possible that certain ignitions, IE multispark, affect them. I don't like them and won't use them.
IF you use tape, take the time to get/ make a positive stop so you KNOW where TDC is. It just is NOT all that much work to scribe 10* marks on your wheel and then divide them down. I used to be able to do this in way less than 2 hours on the car. Easiest if you can get underneath
#355417
06/23/09 09:33 AM
06/23/09 09:33 AM
RapidRobert
I have a dialback & it is a very fun toy to play with but after marking my dampener at different points using pieces of wire measured w micrometers the dial back is pretty much a degree off anywhere and it would have to be as it is using a time delay & different makes of balancers are different diameters so if the dialback is calibrated for a chebby sized dampener the delay wont be correct for us. It may be an insignificant amount but I have remeasured meticulouly & my Sears dialback is not dead on accurate (but I love using it)
[Re: RapidRobert]
#355419
06/23/09 12:41 PM
06/23/09 12:41 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
sb/bb both have a 7&1/4 dampener so yes the MP timing tape is the same. You have a dampener that is not the std 7.25?(1) degree is .0632683". ie 2&1/4"(2.246") is 35.5 degrees
That will vary with the diameter of the damper if his is not 7 1/4 it will be a different distance between degree marks.
#355421
06/23/09 01:19 PM
06/23/09 01:19 PM
Posts: 3,968 North Riverside IL & Lowell IN
GTXKen
super gas
super gas
My damper must be aftermarket (bigger 7.25 tape comes up short)...going to measure tonight to be sure...but think it must be bigger.
Right now, I really need to know 0-90-180-270-0 to set valves.
Do yourself a favor and use a measuring take to find the marks you want and use a scribe to mark them permanantly
#355422
06/23/09 01:19 PM
06/23/09 01:19 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
I used a piece of chalk and marked mine to set mine.
