Mopar Timing Tape #355413
06/23/09 07:49 AM
06/23/09 07:49 AM
Va (for now)
FY1TA & 65 Wedge Offline OP
mopar addict
mopar addict
Va (for now)
I see only one MOPAR timing tape listed?
Does that fit and work for all MOPAR engines....I would think there would be some difference between big/small blocks and Hemi/Wedges engines?
Mr gasket has one for big blocks with 7.25 balancer, but mine balancer is bigger.
Any insight?
Re: Mopar Timing Tape [Re: FY1TA & 65 Wedge] #355414
06/23/09 08:34 AM
06/23/09 08:34 AM
sb/bb both have a 7&1/4 dampener so yes the MP timing tape is the same. I would clean the surface well & iirc use some clear lacquer on top of the tape after it's on to keep it from flying off. You have a dampener that is not the std 7.25? I prefer to find actual TDC then mark the dampener with critical points such as 5,10,15,20,35,36 and 38.(1) degree is .0632683". ie 2&1/4"(2.246") is 35.5 degrees
Re: Mopar Timing Tape [Re: RapidRobert] #355415
06/23/09 08:46 AM
06/23/09 08:46 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
do yourself a favor and go buy a nice timing light w/ an advance on it. the tape WILL fall off.
Coming soon!!!!
Re: Mopar Timing Tape [Re: Mr.Yuck] #355416
06/23/09 09:22 AM
06/23/09 09:22 AM
I disagree. In my lifetime I've seen a number of dialup timing lights on which the delay was incorrect. It may be possible that certain ignitions, IE multispark, affect them. I don't like them and won't use them.
IF you use tape, take the time to get/ make a positive stop so you KNOW where TDC is. It just is NOT all that much work to scribe 10* marks on your wheel and then divide them down. I used to be able to do this in way less than 2 hours on the car. Easiest if you can get underneath
Re: Mopar Timing Tape #355417
06/23/09 09:33 AM
06/23/09 09:33 AM
I have a dialback & it is a very fun toy to play with but after marking my dampener at different points using pieces of wire measured w micrometers the dial back is pretty much a degree off anywhere and it would have to be as it is using a time delay & different makes of balancers are different diameters so if the dialback is calibrated for a chebby sized dampener the delay wont be correct for us. It may be an insignificant amount but I have remeasured meticulouly & my Sears dialback is not dead on accurate (but I love using it)
Re: Mopar Timing Tape [Re: RapidRobert] #355418
06/23/09 09:55 AM
06/23/09 09:55 AM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
Thats what I do, clean the balancer good, apply tape and then I spray some clear engine enamel into a cap and brush it on over the tape. Won't go anywhere.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: Mopar Timing Tape [Re: RapidRobert] #355419
06/23/09 12:41 PM
06/23/09 12:41 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
sb/bb both have a 7&1/4 dampener so yes the MP timing tape is the same. You have a dampener that is not the std 7.25?(1) degree is .0632683". ie 2&1/4"(2.246") is 35.5 degrees
That will vary with the diameter of the damper if his is not 7 1/4 it will be a different distance between degree marks.
Re: Mopar Timing Tape [Re: MoparforLife] #355420
06/23/09 01:06 PM
06/23/09 01:06 PM
Va (for now)
mopar addict
mopar addict
Va (for now)
My damper must be aftermarket (bigger 7.25 tape comes up short)...going to measure tonight to be sure...but think it must be bigger.
Right now, I really need to know 0-90-180-270-0 to set valves.
Re: Mopar Timing Tape [Re: FY1TA & 65 Wedge] #355421
06/23/09 01:19 PM
06/23/09 01:19 PM
North Riverside IL & Lowell IN
GTXKen Offline
super gas
GTXKen  Offline
super gas
Do yourself a favor and use a measuring take to find the marks you want and use a scribe to mark them permanantly
Re: Mopar Timing Tape [Re: FY1TA & 65 Wedge] #355422
06/23/09 01:19 PM
06/23/09 01:19 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I used a piece of chalk and marked mine to set mine.
Coming soon!!!!
