Re: How many drive their street/strip cars to the track ?
[Re: blairboy3]
#355358
06/25/09 03:22 PM
06/25/09 03:22 PM
Posts: 10,766 Central Valley, CA.
Quicksilver440
Central Valley, CA.
Don't go too often, but when I do, I drive 270 miles round trip to Famoso & back. With a C body, you have a built in storage unit! Spare parts, mounted drag radials, nitrous tank, pop-up tent & tools all in the trunk! 12.7 sec car, not the fastest. But, I've seen plenty of slow cars break at the track... especially if they're heavy like mine.
...I can attest to his claim. You wouldn't believe the pile of stuff he had taken out of his trunk....lol. It looked like he was going camping!
[Re: sixpackgut]
#355362
06/25/09 05:57 PM
06/25/09 05:57 PM
BradH
All you guys that drive to the track,what do you do if your car breaks???..wait for the tow truck??...
broke twice. cost $150
how much did your trailer cost?
And the truck to haul it?
Yes, blowing up your street car at the track sucks. For me, it's been only once and the other times I've hurt the car (converter, differential) I've still been able to limp it home. You make your choices and pay for the "piggyback ride" home when things turn out that way.
[Re: sixpackgut]
#355363
06/25/09 06:11 PM
06/25/09 06:11 PM
Posts: 2,924 A shed in England
Tig
A shed in England
Once the car started running into the 11's we sorta stopped driving it to the local track, 75 miles one way and got a trailer. More than once we drove to the track, ran lo/mid 12's on the saturday then drove 50 miles one way to a cruise, back to the track for a BBQ and beers and watch the sun come up. Man I usually felt rough racing on the sunday 250 miles and 20+ passes a weekend @ 10mpg, it was expensive but memorable. Car is still street legal and putts to the local cruise but we trailer it to the tracks now. A 200mile trip usually takes 5 hours due to traffic, crappy roads, roadworks etc and I've broke it a few times now. We hope to get another car which will be a mild street stripper 528ci and hopefully running 11's. Really miss those "road trips"
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: BradH]
#355364
06/25/09 06:16 PM
06/25/09 06:16 PM
Posts: 2,414 St. Croix, US Virgin Islands
David_in_St_Croi
Being a 28 mile long island we always drive to the track. We can see the lights form our house. Our routine is to throw the slicks in the boot, drop the exhaust, which is only 4 bolts each side, then bolt on the collector extensions. Motor on down to the truck. We have friends who have heavy duty floor jacks we can borrow but always bring a small one just in case. We pull in, jack the car up , change to the slicks. lower the torsion bars and off we go. We just leave the tools in a milk crate, our track is pretty good that way. Even if I had drag radials or ET Streets I would still change them at the track as our road would kill them. So far I have broken one axle shaft, lost a rocker arm adjusting screw, and had the clutch go. In the case of the axle shaft, I was able to get to the bottom of our hill as at the time it had a clutch style sure grip in the 8-3/4. I had already called Michelle to bring her Land Rover, a rope and some rum, as she had stayed home for whatever reason. Had to use the Land Rover to pull it up the hill as the sure grip clutch could not hold it. Now, with the Tru-trac in the S60 that is in the car now I would not have been able to make it tot eh base of our hill but the chances of breaking the S60 are much lower, too. The rocker arm I just limped home. The clutch failed by not disengaging so that was not too big of a deal in terms of limping home. So far we have not been bothered by the Gendarmes with the collector extensions on. Once a couple of cops in uniform were working security at the gate. They just said "Sounds good".
#355366
06/25/09 06:19 PM
06/25/09 06:19 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
Call my brother to bring his trailer up and tow me to his house as he lives only 5 miles from Cecil where I usually race. Ron
[Re: roadrunnerreds]
#355368
06/25/09 07:08 PM
06/25/09 07:08 PM
Posts: 871 WA 98043
thecarfarmer
WA 98043
I drove my Valiant to the track and raced, but it just had a stock 383. So I didn't worry much.
My truck will make me worry a bit more about breakage (4.25" crank 383, solid roller); I'll be in the market for a cheap open trailer, and weld a hitch on the Crown Vic when money frees up.
But I'll probably drive it to Bremerton or Pacific (with the 'pucker string' tight) a time or two before a trailer appears...
-Bill
Seduce the attractive, and charm the rest.
489 C.I.D., roller cam, aftermarket heads, tunnel ram, stock '54 Dodge rear axle assembly: which of these doesn't belong?
#355369
06/25/09 07:14 PM
06/25/09 07:14 PM
Posts: 22,873 Chicken coop
dustergirl340
Chicken Little
Chicken Little
Chicken coop
Call my husband to bring our truck and trailer from home 20 minutes away.
[Re: Mr.Yuck]
#355370
06/25/09 09:01 PM
06/25/09 09:01 PM
383man
Balt. Md
"Are you sure they are a drag radial and not a bias tire ?? I know the radial slicks from Hoosier says Radial right on the tire. And the QTP tires that I did run had 2 groves in them but they were a bias tire. Ron"
yup here ya go. They say "radial" right on the side.
I dont think I have seen them from Hoosier before. Are they listed as a drag radial and do they get very sticky ? Ron
[Re: Valiant_Showoff]
#355372
06/25/09 09:48 PM
06/25/09 09:48 PM
Posts: 4,501 Gainesville,FL
goldmember
Gainesville,FL
I made hundreds of trips to the track,most tracks were 25-40miles from the house,one track Jackson Dragway I had 125 mile drive each way. In my 11 second duster only once did I have a failure and that was a flat on the ride home. I plugged it and put air in and got home. some years ago I decided to take my Dakota to the all Mopar race at Jackson Dragway,what could go wrong with a 14 flat street truck? Well long story short,made the finals,won the round and on the U turn to head back to the pits the truck wouldn't pull itself. Darn 7 1/4" rear had enough and left me walking to the pits. Since friends were waiting to tow back to Memphis,we left my truck at the track(owner left the gate unlocked),then dropped a car in Memphis turned around went back(125miles) slid the axle in enough to get it to drive onto the trailer. Got home before the sun came up.I had lots of fun and never missed having a trailer,enjoyed putting cars on the trailer then passing them on the highway to the house.
[Re: Quicksilver440]
#355374
06/26/09 04:23 AM
06/26/09 04:23 AM
Posts: 2,179 California, USA
blairboy3
California, USA
I could have had my own swap meet
1968 Plymouth Fury III 4-Door: 12.79 @ 115, 60'- 1.93 (Hey... it's a Cruise ship... what do you expect?!) Famoso Raceway, 02/08
#355375
06/26/09 07:58 AM
06/26/09 07:58 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
AAA plus... free hook up free tow $150 a year for my wife and I, including all kinds of other services. I highly recommend it.
[Re: 383man]
#355376
06/26/09 08:05 AM
06/26/09 08:05 AM
Mr.Yuck
Brookeville, Md
Drag Radial...got them of of e-bay $238 shipped for the pair. I haven't mounted them up yet but the seem pretty sticky. The guy claims only 4 passes and they look it. Plus he said he was cutting 1.40 60 foot!
