heard a rattle like clacking noise on 440 ?? #355044
06/22/09 09:26 PM
06/22/09 09:26 PM
Kenosha, WI wi/il border
BobN Offline OP
BobN  Offline OP
have 700 miles on 440.
hadnt started car for a few weeks and was up on jacks stand in front,
finished up and lowered back on the wheels
fired her up and heard a clacking like a rod.
i had good oil pressure. 40-50psi
my freind came over and he had me fire it up and wasnt there at first but then the sound appear ed and got louder and louder so i knew he was hearing it.
he said not lower motor like arod. more upper motor and sound almost moved around . could not pin point.like possibly alt bearing or power steering pump ,maybe lifter?
when after 8-9 minutes and went away,
i had great oil pressure the complete time.40-50psi, sound did not get louder when he gave it throttle, said a rod would get louder.
thern all was back to normal,
drove it fine 70miles cruise on sunday to a car show and no problem.
a freind said it maybe ut was a lifter needed to bleed up,
all said not to worry. seems fine
??? any idea what may of been that noise and do I worry?
or just drive it like everone says.
Re: heard a rattle like clacking noise on 440 ?? [Re: BobN] #355045
06/22/09 09:30 PM
06/22/09 09:30 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
If it is gone don't worry about it. Probably a lifter. Don't start tearing into it blind.
Re: heard a rattle like clacking noise on 440 ?? [Re: MoparforLife] #355046
06/23/09 12:07 AM
06/23/09 12:07 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
If you can't duplicate the noise, not much you can do. Just keep your eyes and ears open, maybe give it an oil change and take a close look at the oil and filter guts to see if there's any foreign material in there, metal shavings, etc.
Re: heard a rattle like clacking noise on 440 ?? [Re: DaytonaTurbo] #355047
06/23/09 12:37 AM
06/23/09 12:37 AM
San Gabriel, CA 91775
rexus31 Offline
rexus31  Offline
Exhaust leak?
2007 Dodge Charger R/T, Road and Track Performance Group, Steel Blue 1965 Chrysler 300 Convertible, 383 4V, 727TF, Factory Air, Spanish Red 1964 Pontiac GTO, Tri-Power, 4 Speed, Grenadier Red "What ain't no country I ever heard of. They speak English in What?" - Jules Winnfield
Re: heard a rattle like clacking noise on 440 ?? [Re: rexus31] #355048
06/23/09 01:14 AM
06/23/09 01:14 AM
St. Charles, MO
wingman Online happy
Uncreative Title
wingman  Online Happy
Uncreative Title
St. Charles, MO
Had the same intermittent noise on my 440 when it idled--when I started working on the motor it went away. Then put everything back together it came back!
Turned out it was one of the vacuum-controlled doors on the air cleaner snorkel clattering.
I'd just keep an ear open for the noise to come back and run it in the meantime...
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: heard a rattle like clacking noise on 440 ?? [Re: wingman] #355049
06/23/09 01:25 AM
06/23/09 01:25 AM
Woodbridge,CA
NAS Backyard Offline
Woodbridge,CA
If it's an auto, check the torque converter bolts and the flywheel cover, Ask me how I know...
1970 Challenger Ragtop 426 4 speed 1961 Olds 88 2 dr Sedan 394 4 speed GVOD 1968 Pontiac Firebird 428 4 speed 2000 Ford F-150 2002 HD Roadking 1961 Licence Plate collection 1995 Buick Roadmaster www.nogreenautolaws.com
Re: heard a rattle like clacking noise on 440 ?? [Re: BobN] #355050
06/23/09 08:19 AM
06/23/09 08:19 AM
any idea what may of been that noise and do I worry?or just drive it like everone says.
I'd say bad lifter(or 2). You could ignore it but it'd get on my nerves after awhile. I would bite the bullet & replace them & rebreak in the cam/lifters
Re: heard a rattle like clacking noise on 440 ?? [Re: NAS Backyard] #355051
06/23/09 12:38 PM
06/23/09 12:38 PM
Queens, New York
Harley Offline
Harley  Offline
Queens, New York
You can ask me the same.
Re: heard a rattle like clacking noise on 440 ?? [Re: Harley] #355052
06/23/09 03:31 PM
06/23/09 03:31 PM
MO
P
psycho_440 Offline
psycho_440  Offline
P
MO
yep and mine would go away for awhile and then come back. i guess the flexplate was binding and unbinding. bolts seemed to be tight...but they were to long...DUH!!!!
