Re: Will a 22" radiator work? [Re: Dans 68] #354359
06/23/09 06:00 PM
06/23/09 06:00 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
Talk to the guy's that make the rad. They will know best what there rad can handel. a 22 from one manufacturer may work fine and then again a 26 from a different company may not handel it. I'd talk to the rad company or some speed shop owners who build race cars. They'd know what works keeping a big horse motor cool.
Re: Will a 22" radiator work? [Re: Dougsmopars] #354360
06/23/09 06:05 PM
06/23/09 06:05 PM
Houston Texas
PAINT IT BLACK Offline OP
Got a CHIP on my shoulder
Houston Texas
Did that a little while ago. They told me to go with the 26"
Re: Will a 22" radiator work? [Re: Dans 68] #354361
06/23/09 06:08 PM
06/23/09 06:08 PM
Houston Texas
Houston Texas
Here is a photo showing the relative placement of the 26" radiator to the radiator support.
Edit: I got it figured out. Here's the pic I pulled from PGClassics website. I am just going to do the conversion.
Re: Will a 22" radiator work? [Re: PAINT IT BLACK] #354362
06/23/09 06:21 PM
06/23/09 06:21 PM
sc
68spinnrunner Offline
sc
My stock 22" radiator for my 512 stroker would not keep it cool. Also tryed a 26" stock radiator also would not work. I called U.S. radiator and got one of there 22" 4 cores, does not go over 180 degrees. works great. cost around $600.00 though.but looks almost stock.
Re: Will a 22" radiator work? [Re: 68spinnrunner] #354363
06/23/09 06:27 PM
06/23/09 06:27 PM
Houston Texas
Houston Texas
No pic, huh?
Re: Will a 22" radiator work? [Re: PAINT IT BLACK] #354364
06/23/09 09:09 PM
06/23/09 09:09 PM
Az
Crizila Offline
Crizila  Offline
Az
Some old fert way earlier in this post mentioned that!
Fastest 300
Re: Will a 22" radiator work? [Re: Crizila] #354365
06/23/09 09:24 PM
06/23/09 09:24 PM
IN
ahy Offline
ahy  Offline
IN
Some folks have been sucessful cooling a warm BB with a deep aluminum 22"... but many haven't. The factory went to 26" for a reason. While its apart I'd go ahead and cut or change the the side mounts for 26". With a decent 26" radiator you'll have a good chance of having a robust trouble free cooling system. I've had great results with the stock style 26" aluminum radiator from Mancini on a 496 "B". Combined with a shroud and HV water pump cooling - whether in traffic or sustained high speeds - shouldn't be a problem.
Re: Will a 22" radiator work? [Re: PAINT IT BLACK] #354366
06/23/09 10:14 PM
06/23/09 10:14 PM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
My Bee originally had a 22" radiator. 383 4 speed car... I will be going with a stroked 440 more than likely (prob. 600 hp). Will a 22" aluminum rad. get the job done? or do I need a 26"? I'd rather not cut the core support, but I need to know now because the engine bay is about to get paint.
Works fine on my 472 hemi. I have a 6 blade solid fan and shroud, 180 stat. Runs around 175 when cruising in the heat. Heats up to 185 when idling.
Re: Will a 22" radiator work? [Re: PAINT IT BLACK] #354367
06/23/09 10:29 PM
06/23/09 10:29 PM
600 HP is $ to keep cool on the street-if your 22" is struggling- use a more water, less anti-freeze mixture for maximum cooling
Re: Will a 22" radiator work? *DELETED* #354368
06/24/09 04:44 AM
06/24/09 04:44 AM
sc
sc
Post deleted by 68spinnrunner
Re: Will a 22" radiator work? [Re: 68spinnrunner] #354369
06/24/09 08:05 AM
06/24/09 08:05 AM
Houston Texas
Houston Texas
here is my radiator
No there.
Re: Will a 22" radiator work? [Re: PAINT IT BLACK] #354370
06/24/09 06:58 PM
06/24/09 06:58 PM
Aurora Colorado
BELVEDERE67 Offline
mopar addict
BELVEDERE67  Offline
mopar addict
Aurora Colorado
I have a 26in stock radiator, 7 blade clutchfan and shroud.
on a mild 383, never and issue....ever.
Now have a very good 471 low deck with alu heads and good compression.
No heating issues.......until ambient temp is above 90 and in traffic. Temps up and have had to stop and cool.
Additional hp does make a difference. The hp equals heat comment is oh so true. Id get the 26 and overkill it a bit. Get that question sloved....then don't look back.
Re: Will a 22" radiator work? [Re: BELVEDERE67] #354371
06/25/09 08:05 AM
06/25/09 08:05 AM
sc
sc
pic of my 22 inch rad from U.S. radiator
Re: Will a 22" radiator work? [Re: 68spinnrunner] #354372
06/25/09 08:26 AM
06/25/09 08:26 AM
Houston Texas
Houston Texas
Thanks. Looks pretty good. I've definitely decided to convert to a 26". Simply because the car is in a good place right now to do it. It would be hell to have to do it later, and lets face it: Houston is HOT, and I just don't ever want to have to think about it later. This is what you call learning from experience... I've learned some things the hard way with the Cuda, and I'd be a dope to chance it. I think I like the look of the Griffin radiators better... look even closer to stock (not really though), when painted black. They are more expensive than U.S. Radiator though.
