whats the biggest i can go? #353266
06/21/09 12:03 AM
06/21/09 12:03 AM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
hey guys, about to do my spring relocation and am going to be ordering wheels and tires soon...stock abody 8-3/4 housing, minitubbed reusing the stock tubs, springs will be inboarded to the frame...I figure i can get a 12.5 tire under there without any issues if i run a 15x10 with 7.5bs, but im wondering how tall of a tire I can go...Id like to be able to run a 29 inch or 30 inch if i could...the front of the wheelwell is not trimmed, but i will be moving the rearend back one inch...how tall can i go with just moving the rear back...by the way, car is a 71 scamp (same as dart)
thanks
Post deleted by Defbob [Re: mshred] #353267
06/21/09 12:05 AM
06/21/09 12:05 AM
Re: whats the biggest i can go? #353268
06/21/09 12:10 AM
06/21/09 12:10 AM
Renton Washington
Triple Threat Offline
Renton Washington
1 inch back means 29 would be about absolute max...
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: whats the biggest i can go? [Re: Triple Threat] #353269
06/21/09 01:06 AM
06/21/09 01:06 AM
colorado
chargermop Offline
chargermop  Offline
colorado
On a dart you can get a 29-12.5-15 if you mini tubb, trim the outer lips or roll them and move the rearend back 1". Make sure you center the rear end the not much room to spare...
Re: whats the biggest i can go? [Re: chargermop] #353270
06/21/09 01:16 AM
06/21/09 01:16 AM
colorado
chargermop Offline
chargermop  Offline
colorado
back side
Re: whats the biggest i can go? [Re: chargermop] #353271
06/21/09 01:17 AM
06/21/09 01:17 AM
colorado
chargermop Offline
chargermop  Offline
colorado
back
Re: whats the biggest i can go? [Re: chargermop] #353272
06/21/09 08:04 AM
06/21/09 08:04 AM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
hey man, those are the exact same tires and size that i plan on running, the MT sportsman pros (also been thinking about the similar tire from m and h, but its only a 28 inch)..I do have my wheel lips rolled as well, so hopefully with careful measuring and setup i will be able to pull off the 29 inch...I also noticed that you are running the street lites, which is the same wheel i plan on grabbing for mine...what backspace is on those, and how do you like the construction of them?
Re: whats the biggest i can go? [Re: mshred] #353273
06/21/09 11:17 AM
06/21/09 11:17 AM
colorado
chargermop Offline
chargermop  Offline
colorado
love the wheels they are 7.5 back spacing with a stock rearend
Re: whats the biggest i can go? [Re: chargermop] #353274
06/21/09 11:30 AM
06/21/09 11:30 AM
robin hood country
deaks Offline
deaks  Offline
robin hood country
I am thinking of going to a 31" tyre, my axle is 1" back, will they fit.
About your car, i had 29.5 slicks in the stock location but only 10.5 wide.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: whats the biggest i can go? [Re: deaks] #353275
06/21/09 12:33 PM
06/21/09 12:33 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
cool man, thats the same backspacing im going to be ordering for mine...they look great! i guess it is the street lites and 29 mickeys for me now for sure then
Re: whats the biggest i can go? [Re: mshred] #353276
06/21/09 01:21 PM
06/21/09 01:21 PM
Why go to all of the work to move the springs and mini tubs to put a bigger tire on the car and not trim the front fenderwell I would not move the rear end back either, I did move my rear end forward one inch on my Duster
Re: whats the biggest i can go? [Re: Cab_Burge] #353277
06/21/09 03:43 PM
06/21/09 03:43 PM
colorado
chargermop Offline
chargermop  Offline
colorado
1 why trim the front fenderwell? unless you want 31" tires
2 why not move the rearend back? it centers the rearend in the well and looks better
