Post deleted by Defbob
[Re: mshred]
#353267
06/21/09 12:05 AM
06/21/09 12:05 AM
Re: whats the biggest i can go?
[Re: chargermop]
#353272
06/21/09 08:04 AM
06/21/09 08:04 AM
Posts: 3,420 Toronto
mshred
Toronto
On a dart you can get a 29-12.5-15 if you mini tubb, trim the outer lips or roll them and move the rearend back 1". Make sure you center the rear end the not much room to spare...
hey man, those are the exact same tires and size that i plan on running, the MT sportsman pros (also been thinking about the similar tire from m and h, but its only a 28 inch)..I do have my wheel lips rolled as well, so hopefully with careful measuring and setup i will be able to pull off the 29 inch...I also noticed that you are running the street lites, which is the same wheel i plan on grabbing for mine...what backspace is on those, and how do you like the construction of them?
[Re: chargermop]
#353274
06/21/09 11:30 AM
06/21/09 11:30 AM
Posts: 3,210 robin hood country
deaks
robin hood country
I am thinking of going to a 31" tyre, my axle is 1" back, will they fit. About your car, i had 29.5 slicks in the stock location but only 10.5 wide. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
